Author: Subject: Gas torch + BBQ Bottle ??
kiwirex
posted on 3/9/04 at 09:13 AM Reply With Quote
I was around at a blokes place the other day and saw what looked like a Barbecue gas bottle (holds LPG, I assume, just like mine) with a gas torch on it.
Is that feasible?
common?
Would you be able to weld with it?
If not - braze? bronze weld? (are they the same or different?)
Suppose it'd heat stuff up enough to bend it??
Thanks,
Greg H
David Jenkins
posted on 3/9/04 at 09:39 AM Reply With Quote
Propane is often used with oxygen for brazing and gas cutting - it's not as hot as acetylene, but a hell of a lot cheaper! (and easier/safer to handle)
I don't think it's hot enough for fusion welding - you have to have acetylene for that. Will do just about everything else, though.
posted on 3/9/04 at 10:22 AM Reply With Quote
It turns the metal to coke as it burns so it wouldn't weld. You might be able to braze with it.
kiwirex
posted on 6/9/04 at 08:11 AM Reply With Quote
Thanks guys. :-)
