David Jenkins
| posted on 10/4/14 at 09:16 AM |
Why you should wear face protection when grinding
Found this on a website today...
Broken wheel
Nasty! (but not gruesome)
Slimy38
| posted on 10/4/14 at 09:26 AM |
Some interesting feedback comments though, for example using a cutting disc for grinding, or using a wheel once it was worn down to threads.
The bit that I don't understand is that my grinder has a shield covering half of the wheel. This half is always between me and the disc, mainly
so I don't get covered in sparks. If a disc is going to shatter, then won't it head away from me? Or at the very least bounce off the
workpiece before it gets to me?
Don't get me wrong, I'm not just relying on that shield, I still wear a full face shield, overalls and welding gloves. But it does seem
like as well as PPE a few basic positioning rules would also reduce the risk?
hughpinder
| posted on 10/4/14 at 09:55 AM |
From the deep grooves in the side of the disk, I'd guess its been twisted while 'deep' into the material - they can snatch then and
disintegrate. 9" grinders are a lot more dangerous than 4.5s.
I've had a couple of the 1mm *115 discs let go, and they have so little mass the bits don't really do anything thank goodness, so a good
reason to use them.
Regards
Hugh
Benzine
| posted on 10/4/14 at 10:12 AM |
Yeah I had a chunk of 1mm disc hit my forehead, didn't even leave a mark. I always wear eye protection but I've seen full helmets at the
local welding shop, will get one. One thing i don't understand is how few people use ear protection with grinders.
motorcycle_mayhem
| posted on 10/4/14 at 11:15 AM |
Benzine - yep, me too. I use an ear defender - faceshield combo that I can't recommend enough, labelled as 'Oregon'
No only is it comfortable and quiet, but the ear muffs hold the thing securely at all head angles.
I use my older motorcycle helmets for a lot of things, tree pruning, filling compressed bottles, etc.
I've watched (as have we all) the professionals out there cutting steel, concrete, whatever with large (huge) and small angle grinders. No eye,
ear, whatever, protection. Real men clearly...
davidimurray
| posted on 10/4/14 at 11:42 AM |
I always wear eye protection after being terrified by one of the old timers at work when I was 17! Happily there grinding with no glasses, old timer
came over and gave me some advice, being a cocky young bleeder I gave him a mouthful back. He told me to hold my hand out, and then proceeded to
remove his glass eye and pop it in my hand! He lost his eye grinding! That moment is imprinted on my brain and still sends shivers down my spine!
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
fha772
| posted on 10/4/14 at 03:23 PM |
I've had one hit me in the head before, hurts a bit.
But the disc in that picture has clearly been abused, and not used correctly in the first place.
http://www.ppcmag.co.uk/forum/viewtopic.php?f=47&t=6743&start=105
| posted on 10/4/14 at 06:07 PM |
A friend of my fathers nearly severed an arm when using a petrol powered disc cutter with he wrong type of disc which shattered . After loads of
operations he still hasn't got full use of his arm
