shindha
| posted on 19/12/17 at 10:49 AM |
Replacing rubber bushes advice needed
Hello as per title, I need to replace the bushes on an old SE, now I need to take old ones out and push new ones in, would I be better off purchasing
a cheap press from the internet (sell it back on afterwards) or would I be better off going to a garage with a press and if so how much can I expect
to pay?
thanks for looking
joneh
| posted on 19/12/17 at 11:20 AM |
I did mine on a Fury with two steel plates, a bolt and nut. Then wound them in.
Edit - thinking about it - mine was a two part poly bush but I guess the principle is the same.
[Edited on 19/12/17 by joneh]
Schrodinger
| posted on 19/12/17 at 12:22 PM |
I recently wanted to change the wheel studs on my stylus and a local garage charge me £15 to do all 8.
Keith
Aviemore
procomp
| posted on 19/12/17 at 12:30 PM |
Hi.
Rumour has it there is a Westfield specialist based in Birmingham who do small jobs like that FOC.
[Edited on 19/12/17 by procomp]
shindha
| posted on 19/12/17 at 02:46 PM |
Hi Procomp, Ivan or Mathew, you set up my previous pre-lit. I am planning on having some work done by yourselves I'll give you a shout sometime
tomorrow if you haven't broken up for Christmas.
Regards Shindha
