dnmalc
| posted on 31/12/06 at 08:26 PM |
Flickering lights
Help any suggestionsto over come the following;
When I am welding SWMBO complains that the lights etc in the house flicker even when I am using it on the minimum setting as it is only a 150 amp Snap
On I don't think it should be drawing any significant spikes.
nib1980
| posted on 31/12/06 at 08:31 PM |
turn the lights off
theconrodkid
| posted on 31/12/06 at 08:32 PM |
buy her some candles and tell her they are romantic
who cares who wins
pass the pork pies
dnmalc
Unfortunately her fix is to switch the welder off
macnab
| posted on 31/12/06 at 08:33 PM |
normal
All my neighbours moan when I'm welding, 'it's like a disco in here, bla bla'
To simulate this effect try turning the kettle on & off really quickly...
907
| posted on 31/12/06 at 08:35 PM |
It's Christmas. Shouldn't be a problem this time of year.
Paul G
flak monkey
| posted on 31/12/06 at 08:43 PM |
Its also really good for your computer if its turned on at the time...
Sera
http://www.motosera.com
stevec
| posted on 31/12/06 at 08:57 PM |
Give her money to buy shoes, usually fixes it.
macspeedy
| posted on 31/12/06 at 08:58 PM |
I though it was the wind, could blame it on that!
Edinburgh hogmany cancelled
goodall
| posted on 31/12/06 at 09:49 PM |
get your self a seperate electriy surply coming from a nearby 10kv pole this way it won't affect anyone, would require a bit of money tho
goodall
| posted on 31/12/06 at 09:50 PM |
or just put your foot down
RazMan
| posted on 1/1/07 at 01:32 AM |
My SIP 150 causes the same flickering even though the garage is on a separate feed. I just try and do any welding during daylight hours
Raz
dnmalc
| posted on 1/1/07 at 05:55 PM |
I had womdered if a screening transformer would be beneficial but then the welder has a fairly substantial transformer in it anyway
| posted on 1/1/07 at 09:07 PM |
its an annoying problem that one. My table saw causes the lights to flicker and its only 2kw! Basically a voltage drop as the motor/transformer coils
fill up.
907
| posted on 1/1/07 at 09:41 PM |
You think you've got probs
You ought to see my spot welder... 6000 amps for 0.2sec
That makes street lights dim; or it would if we had any.
Paul G
goodall
| posted on 2/1/07 at 12:10 AM |
but you have to remember your paying for it and its not your problem its the electrity surpply companies
