Lotusmark2
| posted on 6/3/05 at 07:27 AM |
Refurbing calipers and drive shafts
Hi all, I am considering either buying my hubs/calipers etc new or getting old ones and refurbing them myself.
Does anyone have tips on doing the refubing and what sort of result it is possible to get?
Mark
bigbriglasgow
| posted on 6/3/05 at 08:27 AM |
you should try v8dave he seems to have a good enough name in the old refurb game. failing that araracing do the old cortina brakes (zink plated)
Brian
Lotusmark2
| posted on 6/3/05 at 08:29 AM |
Hi Brian,
Thanks for the names.
If possible I would like to do them myself but I would like an idea of what equipment I would need and if there are any "how to" guides
kicking around.
Mark
big_wasa
| posted on 6/3/05 at 08:34 AM |
What calipers are they?
I took mine down to a local firm complete with uprights discs the lot (fully stripped and bearing surfaces covered) and they shot blasted the lot till
they looked like new for £10..They would of just needed paint and seals to be as new....
BUT I left the pistons in to protect the bores and aluminium oxide got down the sides so that when I blew the pistons out with my compressor it riped
them to bits results =£110 bill for new exchange calipers But they are spanking
Lotusmark2
| posted on 6/3/05 at 08:38 AM |
I am looking to get Mini hubs, calipers etc.
So would you say it would be better to strip totally before you get them blasted, then replace the seals and re-construct?
Is that much of a job?
bigbriglasgow
| posted on 6/3/05 at 09:06 AM |
Hiya,
there was some talk on here in a thread about electrolisis please check out the sites below.
Thats about as much help as i can give you
Brian
http://www.bhi.co.uk/hints/rust.htm
http://www.holzwerken.de/museum/links/electrolysis_explanation.phtml
big_wasa
| posted on 6/3/05 at 07:27 PM |
Blastings my fav, I seem to get everything blasted...If you take the pistons out then the bores will need protecting or thay will be hadit !!!!!!!!
greggors84
| posted on 6/3/05 at 10:55 PM |
Whats the best way of protecting the bores when sandblasting?
I phoned a local electro plating firm and they said they could zinc plate both calipers for £5. It sounded like he had done it before so i guess he
will have a way of protecting the bores when they do it.
Also how much are new seals? And do you have to get them from a main dealer or do halfords do them?
Chris
The Magnificent 7!
