<<  1    2  >>
Author: Subject: Weld
Wadders
posted on 3/5/05 at 11:14 PM Reply With Quote
are you having a laugh here or what? It's not rocket science, for most people, practice is all thats required to become a proficient welder. Just remember, if it looks sh#t it probably is.
Al
Good welders like good painters are born not made, giving a natural welder good training only reduces the time it takes for them to develop inborn talent and gives them enough knowledge of the properies of metals not to make potentially lethal mistakes.
flak monkey
posted on 4/5/05 at 07:30 AM Reply With Quote
Originally posted by JamJah
Heard I was slated for my post. Was paraphrasing the edexcel textbook for the BTEC in Welding. Did the course but didnt fancy £300 for the paper.
What you posted originally I believe to be the correct way for a TIG weld in aluminium to look (as you essentially dab the rod in at constant intervals you end up with a weld that looks like (((((((). For MIG/MMA welds in steel they should be smooth as the wire/stick is fed in constantly.
Thats my limited understanding anyway.
Sera
http://www.motosera.com
I love speed :-P
posted on 4/5/05 at 07:39 AM Reply With Quote
surely the best way to test your welding, is how it brakes, ie i did a test peice at the begining of my build on 1 inch squ tube (16 swg) and the metal broke before the weld, so if that happenes you need to worry about the metal not the welding.
Phil
posted on 4/5/05 at 07:54 AM Reply With Quote
When it comes down to it, welding is a skill/art that needs practice, practice, practice.
Training is a major help, and constructive (destructive!) criticism is almost essential. When you're on your own you have to be your own critic, and practice that much more!
NS Dev
posted on 4/5/05 at 09:20 AM Reply With Quote
Originally posted by clbarclay
As nisseven says, being taught to weld by a college is a very good idea. That said, having spent 2 years at college where welding was part of the course, the tuition can be very variable. I lernt more from the couple of lessons when another lecturer was standing in for the normal one.
which college, out of interest. Was it agric college, if so, was it Harper Adams? I did my degree (Agricultural Engineering) there, and the job where I was fabricating was in the prototype workshop at Vicon ltd when they were in Market Drayton in Shrops.
The college I went to was in evesham and did a engineering ND, it was an agric college, but stoped doing agric year before I got there. most of the students there are know doing hair dressing/beauty treatment courses. A good view mind
Currently down on harper's books for september start though, doing Off road vehicle design, next one will probably use a landrover donor
As for BTs comment I would say nature and nurture. If you naturally good to start with then it helps, but significant improvement can be made regardless of natural ability with suitable nurture.
[Edited on 3/5/05 by clbarclay]
Have to say, apart from the final year workload, best years of my life so far were spent at Harper! Built some crazy vehicles and did lots of daft stuff!
Just beware because unless things have changed, your lecturer for offroad vehicle design will no doubt be Alex Keen, who is, unfortunately, a twat! If Geoffrey Wakeham is still there, say Nat passes on his regards though, he is a truly brilliant bloke, immeasurable teaching ability in a very off the wall way!!
Still remember the time we all had a coach trip to a science fair where we entered a competition to build a ground anchor out of paper straws and string, among other things. The various colleges there were making all manner of complex items and busily burying them to the prescribed depths, Geoff took a good look at the rules, dug his hole, crumpled all the materials into a big mess, wrapped the string round it, threw it in the hole and buried it..............and won!!
clbarclay
posted on 4/5/05 at 09:56 AM Reply With Quote
Team build exercises are good fun, during the first week of A levels, we were split up into groups, given paper + selotape and told to build a bridge (capable of supporting a load with what we had got.
The team I was on got disqualified when the secret to are bridges strength was discovered. We used what we had got that included the broom (know without a handle attached) that was in the corner.
Nisseven
posted on 4/5/05 at 10:08 AM Reply With Quote
Well while I was at work you guys were busy.
Dave. It's not hard, learn to do it properly then your welds will look good as well as be good.
donny. Good stuff.
N S Dev. Please don't encourage them. You obviously have good natural ability and in your job you have obtained the knowledge. As far as being regulated goes, it is all the crap workmanship that happens that is the main cause of it.
b t. Have faith, welding is not hard and with proper training and a decent machine you will save time and money. Excessive welding and grinding is not a good thing esp. on such thin material.
Cita. Please don't be a smart arse. I did not say only pro welders should build these cars! All I said was learn to do it properly. Welding is one thing you will not learn from a book. I am already a trained mechanic but there are still things there that I have to get advise on.
Gazza. You're not in Aussie are you? Huddersfield sounds very English to me. Any way the wisest words spoken so far.
JamJah. See what I mean. You probably did not explain the technique properly, or you have a crap book. I took it that you were placing a series of blobs one overlapping another ie. stop start stop start.
Wadders. You're right it is not rocket science but you're wrong when you say all that is required is practice. You need to know what to practice first, then, practice makes perfect.
Bruce
NS Dev
posted on 4/5/05 at 10:48 AM Reply With Quote
Totally off-topic, but the Harper Course should be good. Off Road Vehicle Design was a module part of my degree there and I did learn a lot about traction theory, and even handling of vehicles and the like. For one of my assignments I even tweaked the brief a bit and looked at the theory of steady state cornering and it's effects on suspension forces and tyre forces. Seem to remember coming across some old stuff from Colin Chapman on that one!
gazza285
posted on 4/5/05 at 06:11 PM Reply With Quote
Nisseven, sorry mate.
Huddersfield is in the fine county The West Riding of Yorkshire in the North of Blighty. A career in engineering has led me to being introduced to what is called the Hollywood welder, good at acting the part but nothing else. Luckily for the Locost builder the welding can all be done downhand, which allows for a fair bit of, how can I put this, interpretation of technique. Positional welding usually sorts the wheat from the chaff, and the welding inspector definately does.
I have seen the results of weld failure and it is not pretty.
NS Dev
posted on 4/5/05 at 06:23 PM Reply With Quote
true, but then again out of position mig and out of position MMA are two very different things. Will put my hands up now and say that out of position MMA is a ruddy pig! I find that 7 out of 10 times I can do an in situ pipe weld ok, and the other three are useless. If I ever have to cut out a piece and go back I can just never make a pretty job of it. It may be clean and hold pressure but just looks crap, especially if the cut out was on the vertical down! Probably shouldn't have said all that given that I am not certified!
gazza285
posted on 4/5/05 at 06:38 PM Reply With Quote
Phil
Trouble is the metal might have given way because you have put too much heat into it while welding it.
Cita
posted on 4/5/05 at 08:07 PM Reply With Quote
Oooooooh touchy!
Rorty
posted on 5/5/05 at 05:42 AM Reply With Quote
I have never been on a welding course but have been asked numerous times whether I am a professional welder.
Why...do you have a red "V" on your chest?
Cheers, Rorty.
Rorty
posted on 5/5/05 at 05:54 AM Reply With Quote
I'm not a "Welder", but I can buzz cars together OK.
A pipeline welder I know once said "Any idiot can weld and most of them brag about it too".
Cheers, Rorty.
NS Dev
posted on 6/5/05 at 12:35 PM Reply With Quote
ok ok
I was only saying that a few people that have seen my car(s) have asked if I welded for a living, thats all!
I certainly don't brag about it ( I have worked with too many people better than me to do that!!!)
I don't like people telling me that I shouldn't be welding my cars together because I am not qualified though, when I have worked with people who are qualified and who's work is far worse than mine!
johnjulie
posted on 9/6/05 at 09:45 PM Reply With Quote
After two years at welding college, 1st year flat, and 2nd vertical, 3rd overhead if I take it, I would honestly recommend that anyone wishing to build their own chassis from scratch, should not attempt it withought some prior proffesional training. I have found through experience that although a weld may look perfect visually, it's not until the weld is cut open that the true details of fusion and penetration can be seen. Welds that look fine on the outside are often lacking both fusion and penetration, crucial to the strength of the joint. It takes a fair bit of practice to get anywhere near competent.
Practice certainly makes perfect, especially with expert tuition.
Mine is an evening course, ABC levs 1,2 & 3, but many colleges run 6 or 12 week introduction courses, specialising in various types of welding.
I'm doing gas, mig, tig & MMA(stick), and I find each one has its merits. For most jobs, and the most affordable, I would recommend mig. There are often good books on Ebay, the best all rounder is:
The Science & Practice of Welding. VOL 2
by A.C. Davies. Covers all types of weding. Excellent, but expensive.
Cheers John
posted on 9/6/05 at 11:13 PM Reply With Quote
I used to arc weld vessels in a foundry and do repairs on castings but never did formal courses. I took a job fork truck driving at a place and one of the trucks was in for a guard repair as it had been hit with something. The fitter was making heavy weather of it, sticking the rod and swearing a lot so I asked if he wanted a hand. He asked if I could weld and I said, " Can't everybody?" Turned the power up and put a run round it. He was impressed and I was surprised he'd had a welder lying round and never bothered experimenting with it.
<<  1    2  >>
