Author: Subject: Need a chemist's advice
posted on 23/6/09 at 12:21 PM Reply With Quote
No, not about a nasty skin disease, it's about making up a chemical solution!
I need to make a citric acid solution, which has been specified as "10% by weight". I have a small tub of citric acid in crystaline form, and a lot of water. Can someone advise how I can combine the two to get the solution I require?
I know three-fifths of f**k all about chemistry...
BTW: this solution is for passivating stainless steel, so it is something to do with Locosts...
posted on 23/6/09 at 12:24 PM Reply With Quote
Easy. Weigh out 10g of citric acid. Combine with 90ml of water. Job done
posted on 23/6/09 at 12:30 PM Reply With Quote
Doh!
Even I can cope with that...
Cheers.
andyharding
posted on 23/6/09 at 01:46 PM Reply With Quote
Dunno if it's like other nasty acids I've used in the past but you should always add the acid to the water not the other way around or it might go bang in your face
posted on 23/6/09 at 01:48 PM Reply With Quote
Not a problem with crystals...
Also, citric acid's quite mild in comparison with the other usual suspects like sulphuric or nitric.
iank
posted on 23/6/09 at 02:58 PM Reply With Quote
Still put the crystals into the liquid. It makes a weak acid that gets stronger as you add them, rather than a strong one that gets weaker if you get what I mean.
Less chance of splashing as well.
Anonymous
Mark Allanson
posted on 23/6/09 at 04:42 PM Reply With Quote
I don't think it is as simple as 10g crystal to 90ml of water. I seem to remember something about molecular weights being used which is the total atomic weight of the constituent atoms, eg a mole of oxygen is 16g (atomic weight 16) - but get someone else to confirm as it is a VERY long time since I learnt any chemistry, they called it alchemy in those days!
mads
posted on 23/6/09 at 04:54 PM Reply With Quote
Mark, what you are referring to is to do with concentration in terms of moles.
In the pharmaceutical world, 10% by weight would be 10g of substance A in 100g diluent so for David, as suggested it would be 10g Citric acid (as long as it is pure and classed as 100%) with 90mL water. (we would class water as 1mL = 1g)
We dont use Wikipedia at work as a reliable source of information but in this instance it is correct
HTH
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
