Author: Subject: Bending ali tube
shortie
posted on 5/11/09 at 10:12 PM Reply With Quote
Bending ali tube
Want to bend some ali pipe for cooling tubes.
Is there any reason why I can't just use a bending spring, heat it up and bend away!!!??
Rich.
[Edited on 5/11/09 by shortie]
locoboy
posted on 5/11/09 at 10:14 PM Reply With Quote
No reason that i can think of.
I normally grease the spring before use to make it easier to pull out, just make sure you pull a rag through the tube and wash it out with some solvent/petrol and im sure it will be fine.
Locoboy
blakep82
posted on 5/11/09 at 10:18 PM Reply With Quote
it might crease/wrinkle the inside, but since its not needing to have any stress through it (like wishbone tubes for example) then i can't see a reason why not, except it might look a little funny on the inside of the bends
________________________
austin man
posted on 5/11/09 at 10:22 PM Reply With Quote
tape one end with duct tape, completely fill with dry sand add water tape the endand gently bend. there is something on youtube using this method. if the pipe is small enough springs or a plumbers pipe bender
posted on 6/11/09 at 07:02 AM Reply With Quote
you can get curverd aluminium pipe on ebay - usually the large diameter for intercooler .
posted on 6/11/09 at 08:48 AM Reply With Quote
That's exactly what I was going to suggest
Otherwise is it possible to use a bending bar?
PHULL
posted on 11/11/09 at 09:50 PM Reply With Quote
pack mine with sand and then anael the tube and burry it in sand to cool it very slowly. then pack the pipe tightly and then clamp it in that tool and bend away.
I find the anaeling and how hard you pack the sand relates to if the pipe kinks or snaps like I have on a couple of occasions
RK
posted on 13/11/09 at 01:48 AM Reply With Quote
You might think this is a really stupid thing to say at this point, but don't use your wheel hubs for this: you get creases. I had good luck with my knee however. Live and learn and pass it on I always say...
