blakep82
| posted on 24/1/11 at 09:01 PM |
pipe beading tools
anyone had any experince in making something like this?
Pipe / Tube Beading Tool on eBay (end time 02-Feb-11 13:01:11 GMT)
i know there's the oyster tool, i've got one, and i don't think it gives a wide enough bead personally. i've tried pliers with
a lump on one side and groove in the other, and i didn't work very well, so, has anyone ever tried making anything like this?
ther must be a way of making something from an old vice... 2 wheels, one small, one big and use the vice to clamp them together, but i can't
work out how without it being all wobbly
[Edited on 24/1/11 by blakep82]
________________________
MakeEverything
| posted on 24/1/11 at 09:05 PM |
Ive never used an oyster tool, has anyone else got one?
Only joking.
Kindest Regards,
Richard.
Howlor
| posted on 24/1/11 at 09:11 PM |
Like this?
[Edited on 24/1/11 by Howlor]
blakep82
| posted on 24/1/11 at 09:15 PM |
lol yeah, exactly like that! never seen one like that before, was just something i dreamed up in my head lol
wasn't sure if drilling the ends of a vice would be possible (aren't they hardened steel?!) or if bolts would be strong enough
Richard, careful now!
Strontium Dog
| posted on 24/1/11 at 09:18 PM |
Or this and easy to use with the driven roller, but I like the vice idea! Top!
Blackbird Rush
| posted on 24/1/11 at 09:27 PM |
Locost way is to put 3 pop rivets in the tube equi-distant apart this then gives an edge for the hose clip to secure to so it wont blow off.
Has been fine in my bike engine, used for the top & bottom rad hoses.
Ash.
blakep82
| posted on 24/1/11 at 09:29 PM |
hmm some good ideas there, sure it would be easy to have some rollers made up,
can a vice be drilled and tapped easily? i think i've got a spare small one hanging about somewhere, might donate itself...
driving the outer roller might be easily done with a few extra holes and a grinder disc tool thingy
Howlor
| posted on 24/1/11 at 09:33 PM |
If you can't drill the vice body why not just make up two new vice jaws and drill those. These can be screwed on to the vice assuming it has
removable jaws fitted.
tomgregory2000
| posted on 24/1/11 at 09:34 PM |
I would stick to the oyster tool.
Ive done my water pipes and turbo boost pipes with the tool and have not had any hose come off, boots runs at 1.2bar.
Just make sure you use propper hose clamps
Benzine
| posted on 24/1/11 at 09:42 PM |
This tool looks great, just clamped into a bench vice (bit pricey though compared to the
above vice solution)
MakeEverything
| posted on 24/1/11 at 09:51 PM |
Blake, i use these;
  Swage Tool
  Pipe Swage 2
  Coolant Pipes 3
Kindest Regards,
Richard.
blakep82
| posted on 24/1/11 at 09:53 PM |
that looks alright actually richard, are they ratchet type electrical criping thingys?
MakeEverything
| posted on 24/1/11 at 09:55 PM |
Yes, theyre the type that crimp the lead sleeve on electric meters, but they have been decommissioned. You might be able to modify a normal set
somehow?
Kindest Regards,
Richard.
