matt_gsxr
| posted on 12/5/12 at 03:10 PM |
Anyone with a lathe in Oxford area?
Hi there,
I've decided to sort my triggering problems out, once and for all.
So want to make a 32-1 trigger wheel for my suzuki engine from these two parts.
  trigger_wheel_job
Basically make the 32 tooth wheel into a ring gear.
Turn down the stock Suzuki wheel.
Bit of heat/freezer to fit them,
then presumably check or tidy up to ensure its central.
Should be easy with a lathe, happy to pay a few quid, but keen to get it sorted ASAP.
Matt
Edited to add that the diameter of the whole assembly is 2inch diameter, so even a small one would do the job. They are both steel, but not the
really hard kind ;-)
[Edited on 12/5/12 by matt_gsxr]
tegwin
| posted on 12/5/12 at 03:32 PM |
Would make sense to turn a shoulder onto them both so they "self jig" in both axis. And then apply a couple of spot welds to hold it all
together?
Would offer to sort it for you but I have big exams this week. After Fri I am free for 4 months, so if your stuck... :p
www.verticalhorizonsmedia.tv
matt_gsxr
| posted on 12/5/12 at 08:27 PM |
Good thought that.
Remarkable how few people have lathes "down south".
You might be getting a call on Friday. Good luck with the exams.
Matt
edited because I can't spell
| posted on 13/5/12 at 08:31 AM |
That would be a 36-1 wouldn't it ? Could you take the centre out of the tooth wheel so it centres on the nut in the bike trigger then drill and
tap to hold it in place using the bike one as a carrier ? You could slot the hole to give some adjustment then drill another to lock it when
it's set right.
theprisioner
| posted on 13/5/12 at 10:00 AM |
Not a very practical solution, but I have all you need in terms of a workshop machines in Scotland. If you get stuck then mail them to me!
Questions if you take up my offer
1) Are you shure both parts are steel try a magnet if not?
2) The gap in the toothed wheel, is it's position critical in relation to the other wheel?
I think tegwins suggestion is the correct one!
Cost: The postage both ways!
matt_gsxr
| posted on 13/5/12 at 12:15 PM |
yes 36-1. Just a silly typo.
thanks chaps
matt_gsxr
| posted on 15/6/12 at 08:19 AM |
together?
Thanks Tegwin,
This was a great tip. Wouldn't have thought of doing it this way, but I did what you said and I can now see why it is essential.
Matt
