Bob da builder
posted on 4/12/04 at 08:19 PM |
Sandblasting?
hey up
does anybody have any first hand experiance with the sandblastes for sale in machine mart that run on compressed air as i was thinking of getting one
to strip down a triumph chassis. but dont realy want to waste my money if they are as useless as chocolate tea pots!!!
cheers
bob
| posted on 4/12/04 at 08:29 PM |
If you mean the ones that look like a pressure pot on legs you need a massive fad to power them. My mate used to run one of an ex gas board van with a
built in compressor and I think anything smaller would struggle.
Mark Allanson
| posted on 4/12/04 at 08:48 PM |
I have a suction cup one (looks like a spray gun). Its fine for small stuff, but I think a chassis would be beyond it. It would also work out
expensive on grit too, a cup lasts about 30 seconds
wilkingj
| posted on 4/12/04 at 08:49 PM |
I built a cabinet tyrp sand blaster.
£25 for the metal, and £25 for a clarke sandblasting gun.
It makes my 14CFM (3 HP motor) 150L tank, run almost continuously.
I chose to make a big cabinet 700mm Cube. the otherones like the Pot type, shove the blasting medium everywhere.
You will need an Air fed mask with filter as you do NOT want to breathe in all that dust, rust, sarbon, silica, and everything else.. I assume you
want to keep breathing through a decent set of lungs!!
As PeteF says... you want a Mega compressor. preferable a 3 phase job to keep up with the blasting.
Take it to a blasting shop... it will cost less than all the kit and is more healthy for you.
Organise it so you can pick up the cleaned chassis, and take it to a paint shop or paint it the same day (or Galv it!).
My little blater is great for small items, but a whole chassis?... not big enough for
that!..
[img]/upload/DSCF0079.JPG[/img]
My Locost Blaster
[Edited on 4/12/2004 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
Bob da builder
| posted on 5/12/04 at 09:25 PM |
cheers for the info guys, i will take your advice and get it done by a pro with all the gear!! and i like the idea of galvanising it!! stop my
spitfire chassis rotting before my eyes!!!
take it esay
bob
krlthms
| posted on 6/12/04 at 01:23 AM |
Bob: Look at Kimini's site from this forum:
http://www.kimini.com/
In his last progress posting, he has some nice pictures of the process of sandblasting a chassis.
Wilkinsj: Would you want to sandblast a chassis if you are going to galvanize it? Acid clean?
KT
