macspeedy
| posted on 6/4/05 at 09:27 PM |
need gasket material
We got a compressor that has asthma so we have assembled the unit as it was in large bits to enable us to transport it. The head gasket is fooked so
we need some gasket material to make a new one.......WHO SUPPLYs such a thing or does anyone have any kicking around 10" x7" in
cork.
rayward
| posted on 6/4/05 at 09:45 PM |
could get you some caf (compressed asbestos fibre) gasket material if that would do??
Ray
mangogrooveworkshop
| posted on 6/4/05 at 09:56 PM |
That would do the trick as it works under major heat when pumping.
Macspeedys on the road home so I will u2u him with the details. Of course I do understand asbestos and the dangers of it......Dad worked for Everite/
Turners asbestos in SouthAfrica......
flyingkiwi
| posted on 7/4/05 at 06:11 AM |
I'm sure I have a large(ish) sheet of gasket paper out in the garage, will have a look this morning and find out for you.
Chris
It Runs!!!!! Bring on the SVA!
lewis635
| posted on 7/4/05 at 04:14 PM |
I know you will think i am taking the p**s but i used to run Challenger tanks with gaskets made from cornflakes Boxes.
This was far better than any gasket paper we could find, But thats the british army for. Making the best of S**t Kit.
flak monkey
| posted on 7/4/05 at 04:17 PM |
Card and paper work wonders as gaskets. With a bit of gasket sealer like Haematite they are cheap, simple and effective.
Not recommended for critical applications, but will suffice for most things.
Sera
http://www.motosera.com
owelly
| posted on 11/4/05 at 08:09 PM |
If you get stuck, PM me and I will post you whatever you need (within reason!!)
http://www.ppcmag.co.uk
