drmike54
posted on 12/8/05 at 12:09 AM |
MIG Wire?
What size wire are you using for your car? I just got my metal yesterday and I am eager to start! I have both 0.024 inch and 0.030 inch wire and
tips.
Started Welding the chassis!!!!
suparuss
| posted on 12/8/05 at 05:16 AM |
i think most people will prefer the bigger one (we call em 0.6 and 0.8 mm over here in metric land) if anything its better because theres less chance
of it kinking in the wire feed. i would only use the smaller stuff for really thin sheet etc.
NS Dev
| posted on 12/8/05 at 08:01 AM |
yep. You'll find you can weld pretty much everything with the thicker of the two.
I have welded plenty of 0.8mm steel sheet with 0.8mm wire, no bother.
