bigandy
posted on 18/9/05 at 10:29 AM |
HOw hot should a compressor get?
MOrning folks.
I've just run up a new compressor (Rockworth brand, 2HP, 24L reservoir) and it seems to work pretty well. I was wondeirng though if someone
with a similar compressor could tell me how hot the pipe between the pump and resrvoir gets in use?
After about 3min of running (to get to just under 8Bar pressure) the pipe is almost too hot to hold, and I was wondering if that was normal?
Dammit! Too many decisions....
Triton
| posted on 18/9/05 at 10:35 AM |
Yep the delivery pipe gets mega hot on all compressors......don't touch it
| posted on 18/9/05 at 10:39 AM |
Yes
There's a lot of friction going on there. That's why you get condensation in the tank and need traps in the airline.
Ben_Copeland
| posted on 18/9/05 at 12:25 PM |
Yep, they certainly do get hot
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
| posted on 18/9/05 at 01:14 PM |
Have you seen how hot even a bicycle pump gets when worked hard? your compressor is working a lot harder , one of the requirements for big compressors
is an unrestricted air supply , not only to feed compressor but also to cool it.
bigandy
| posted on 18/9/05 at 04:12 PM |
Thanks folks.
I knew it would get a bit warm, but I wasn't expecting it to be quite as hot as it was!
bigandy
| posted on 18/9/05 at 05:43 PM |
Oooh, another thing I was going to ask, does anyone know what the fitting on this compressor is? It seems to be a brass thing with a sleeve that
slides along slightly.
I'm guessing it some kind of quick release thing...
| posted on 18/9/05 at 06:12 PM |
I took the ones off that came with my compressor and replaced them with proper PCL quick release fittings. http://www.indanc.com/products_pcl.htm I
got mine from the local hardware but Clarkes or similar should have them.
big_wasa
| posted on 18/9/05 at 07:17 PM |
yep bin them and get plc..machinemart do them aswell....
Triton
| posted on 18/9/05 at 07:25 PM |
broomwade type are better as they don't fly off....they twist n lock like a light bulb.
| posted on 18/9/05 at 08:49 PM |
The Broomwade ones as made by PCL .
http://www.pcl.org.uk/p_ca_instantair.html
[Edited on 18/9/05 by Peteff]
