| posted on 22/12/05 at 01:59 PM |
tapped rivets?
Is there such as thing as tapped rivets? I want to insert a threaded tube into square tubing where there is no access to the rear?
I have used rivnuts but these were the sort where you splay the end with a punch and fitted to sheet where you can access the rear.
phooka
| posted on 22/12/05 at 02:04 PM |
Something like this? http://aircraftspruce.com/catalog/hapages/rivnuts.php
| posted on 22/12/05 at 02:08 PM |
You can get rivnuts that you insert with a tool like a pop rivet gun. If you only need to fit a few it is easy to make a toll using a ste screw, a nut
and a washer . Just drill hole to suit rivnut, screw nut onto setscrew and fit washer. Screw on rivnut until setscrew is through it , insert into hole
and using 2 spanners , one to stop setscrew turning the other to tighten nut until rivnut is set. HTH
| posted on 22/12/05 at 02:10 PM |
yep - that will work - cheers! now to find cheap UK source!
clbarclay
| posted on 22/12/05 at 02:28 PM |
Here is fairly cheep.
http://www.fastfixdirect.co.uk/code/FilterResults.asp?fType=Fasteners&MainCategoryID=55905&ProductCategoryID=347
Just sellect the size your require, avalibe in aluminium, mild steel and stainless.
planetester
| posted on 22/12/05 at 04:45 PM |
Try this link, I got some & they are great & you dont have to buy 100's
http://cgi.ebay.co.uk/STEEL-RIVNUTS-M4-5-6-8-80_W0QQitemZ7574805388QQcategoryZ64819QQcmdZViewItem
planetester
| posted on 22/12/05 at 05:00 PM |
Forgot to say that you can react them with a bolt , nut, some lubricated washers & 2 spanners, no need to buy the special plyers
sorry Rusty nuts has alreadt said that !!!
[Edited on 22/12/05 by planetester]
Deckman001
| posted on 22/12/05 at 05:08 PM |
I use this company http://www.1-stop-fasteners.co.uk/ for all my work fixings, I can't find on the site the rivnuts, but they deff do them so
you'll need to call, they also do s/s bolts and nuts to high spec
Jason
RazMan
| posted on 22/12/05 at 06:21 PM |
02GF74 - I think the items you are referring to are called clinch nuts or something similar.
CBS do a nice little Rivnut kit to start you off for £22.50. He also stocks alloy and stainless rivnuts too.
[Edited on 22-12-05 by RazMan]
Raz
piddy
| posted on 22/12/05 at 10:51 PM |
Most industrial nut/bolt supplier do them.
Just ask for rivnuts or clinch nuts.
