suparuss
| posted on 13/1/06 at 08:53 PM |
mig liner?
heard about these teflon liners for me mig and also vaguely heard that pedal-iron brake cables fit? is this true? tis a sip mig 150t.
if they are the same size ill give em a go cos the liner in mine needs a change desperately!
Russ.
stevebubs
| posted on 13/1/06 at 09:00 PM |
Why not get the genuine stuff? It's not that expensive...
linky
RazMan
| posted on 13/1/06 at 10:02 PM |
That's where I got mine last week - about £8 IIRC. Very helpful too
Raz
big_wasa
| posted on 13/1/06 at 10:05 PM |
Ive got the same machine. replaced mine with a steel item and it made a big differance. It does look like a bike cable Teflon item is dearer maybe
its better still. The steel linear ment you could hold the torch at any angle and it would still feed fine. The cheap plastic item would make it spit
and fart unless it was absolute straight.
just my opinion..............
Mark Allanson
| posted on 13/1/06 at 10:13 PM |
The plastic ones wear a groove which pinches the wire, the teflon ones do the same but after a much greater time scale
| posted on 13/1/06 at 11:39 PM |
my whole welder is getting aged, the torch is in pieces again. I dont mind having to strip it and fix it, but twice in a day is getting too much...
suparuss
| posted on 14/1/06 at 04:41 PM |
sound ill order the proper one then, wasnt aware you get get em especially.
think mine probably has more grooves than a 70s disco by now cos i havent changed it in about 2 years!
Russ.
