Patching Cars
| posted on 13/3/06 at 11:10 PM |
Air Regulator & Filter
I got one of the mini regulators & filter from Machine Mart the other day:
However alot of air comes out the hole in the bottom, should there be a captive nut on the end to stop air leaking out?
Rob
skydivepaul
| posted on 13/3/06 at 11:14 PM |
There should be a plastic cap with a spring loaded pin which when under presure makes a seal. When the air pressure is off you can push the pin
upwards to drain the water from the trap.
Looks like you have a bit missing
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
