NS Dev
| posted on 18/4/06 at 10:12 PM |
Tig welders again!
Right!
Think I have convinced myself that as the materials for my manifold came to £200, I can spend around £400 on a tig welder and still come out cheaper
than a manifold from leading manufacturers.........so........after me offering lots of advice on here its my turn to request some!
Whats the best features per quid spent DC only TIG machine, used or new. Would rather go for a used properly built machine than a new inverter that is
scrap if it goes pop!
(I'm guessing £400 used machines are going to be tricky to find with AC-DC operation, and most work will be steel anyway so hey ho!)
What do you reckon?
(I'm really looking for a s/h one with foot control etc etc included)
caber
posted on 18/4/06 at 10:27 PM |
Get HF start and make sure you have enough amps. Inverters are OK these days, there are a few companies out there who do OK new kit cheap, GYS spring
to mind, the Sealy range can be bought cheap with other names on the side, they are also OK but pay minimum for them and spend the extra on the
extras! Remember you will need gas regulator / bottles, and foot pedal.
The older TIGs and many of the AC/DC ones need 3 phase so this may or may not be ok for you.
TIG is a great process but does take practice to get good, easier if you gas weld than if you are used to MIG or sticki
good luck
Caber
MikeR
| posted on 18/4/06 at 10:54 PM |
go on, get AC/DC you know you want too and it means i start giving you more beer tokens / beer for odd jobs
think how much you'll save if you can weld ali?
heck, you could even do your own fuel tank, header tank, all sorts in future........
(i know, i'm a person without a father!)
NS Dev
| posted on 18/4/06 at 11:04 PM |
can't justify a grand Mike, much as I'd like to as I see a rather nice transformer based AC-DC machine on ebay now for £985!! (and
it's british built)
MikeR
| posted on 18/4/06 at 11:09 PM |
but its not a grand, its 600 quid more than you want to spend. thats all.
so you still haven't got the bike engines for next years grasser - which means you have the money. Get the welder then earn the money back doing
jobs for other people.
Then that way you get the welder you want and can still get the engines. Plus if i get the megasquirt stuff sorted on my car i'll be able to
help you run the grassers via that saving you money on the ecu - which means you'll actually end up with more money in your pocket and happier
with more toys!!!!!!!!
Sales .......... no, i'm in IT, just feels like sales some days.
mark chandler
| posted on 18/4/06 at 11:10 PM |
I,d look for a copper wound Millers or Lincoln off Ebay.
Most American commercial welders run 1, 2 or 3 phase (although will be sold as 3 phase aa thats what they will have been connected as), you just need
to strap em right and run a heavy lead from your consumer unit. 60 amps @240v for 200 amp welding @83v
Do not look for features like slope in/slope out and all that cleverness, you just need remote on/off, foot pedal (These are not the same as invertor
pedals as they have big reostats inside) and post gas delay.
If its goes wrong (which is extremly doubtful) beyond the coils its all solid state, big transistors, capacitors etc that you can replace, no tricky
ECU's here.
Regards Mark
NS Dev
| posted on 18/4/06 at 11:19 PM |
Cheers Mark, that's sort of confirmed my suspicions, can I u2u you if I see a likely candidate on t'internet just to run it by you?
I know Mike!!! But selfish as it sounds I never have enough time on my own car now!! Spent 2 hours tonight on the phone to a mate diagnosing a 205gti
that wouldn't start, but it drove to work this morning. Not a bad diagnosis by phone! Managed to tie it down to ECU failure or intermittent
connection between coil -ve and ecu/tach relay....toook a bit over the phone to work out that the fuel pump was there on cranking, we had sparks, we
even had power to the +ve side of the injectors, but the ECU wasn't earthing them. not bad for the chap on the other end of the phone with some
pliers, a screwdriver and a length of wire and a sidelight bulb from the car!!!!
Rattling on but that's how I end up not getting my car done!!!
Anyhoo, would love to get the ACDC machine but just struggle to see how I could get the £600 worth of work in to pay for
it......................................................................
MikeR
| posted on 18/4/06 at 11:22 PM |
read your email - i have a solution!
(and no its not selling your body - that wouldn't make 600 quid in 10 years!)
907
| posted on 18/4/06 at 11:25 PM |
IMHO a foot pedal is not needed on a DC machine.
Ally is another can of worms. When you start an ally weld the metals cold.
As you progress it warms up, and come the finish it's as hot as hell. A foot pedal's great.
Steel and stainless however doesn't conduct heat as much, so setting the heat on the machine is no problem.
Just my 2p
Anyway, you don't need it yet. Wait till I can afford my new Lincoln, and then buy my Sure Weld.
Paul G
NS Dev
| posted on 18/4/06 at 11:28 PM |
how much for the sureweld? (what model etc etc)
know what you mean (I think!) on the foot pedal, just from migging ally I know its rapid conductivity and high heat capacity make it a swine!
Thought it might be nice on thin stainless coming up to outside corners and the like just to make life a bit easier.
907
| posted on 18/4/06 at 11:38 PM |
My cans were .7 thick.
35 amps, no prob.
I'm contemplating knocking up a batch.
It would pay for the Lincoln.
Paul G
p.s. Start on an edge and work in.
[Edited on 18/4/06 by 907]
mangogrooveworkshop
| posted on 19/4/06 at 02:08 AM |
http://www.westermans.co.uk/Ltec250tig.htm
These lads take machines and overhaul them.
Ive not used them but they may be of some help to the cause.
NS Dev
| posted on 19/4/06 at 09:26 AM |
Cheers!!!!!!!!!
once again locostbuilders comes up trumps!!!
Thanks!!!
They are all of 4 miles up the road from where I work, and have some transformer/thyristor based 220v ac-dc machines in stock.
price is not cheap but considerably less than an equivalent new inverter based machine...................
getting serious now!!
MikeR
| posted on 19/4/06 at 09:37 AM |
BUY BUY BUY BUY
you know i want you too !!!!
NS Dev
| posted on 19/4/06 at 09:49 AM |
still going to be a grand by the time I have got set up with gas etc etc etc and will really need to put a proper connection unit in the garage for
this jobbie, can't really stick a 200amp tig on a 13 amp plug........,but then my 220 amp mig is!!!
MikeR
| posted on 19/4/06 at 10:52 AM |
well it should be running through that cable i gave you so the feed should be ok (you are using that 40 / 45 / 50 amp (i can't remember) cable
aren't you?)
NS Dev
| posted on 19/4/06 at 11:37 AM |
Still on the previous cable (was it 6mm or 8mm that you gave me??) mine was normal cooker stuff, yours was bigger than that!!!
Must get that swapped over, but yep, on 45 amp cable at the mo anyway.
std 13 amp plugs are not the done thing though, as you can only get 13 amp max fuses for them.
On full power I use an alternative "fuse" but I don't think that's the done thing either as I can't see a 6mm bolt
"blowing" very easily!! The circuit is all protected by an appropriate MCB and RCD anyway having said that.
ned
| posted on 19/4/06 at 12:27 PM |
ooh you bad. i got flamed a while back for mentioning the word 'nail' in that context
my 160amp mig runs fine off the 13 amp plug and extension lead though the cord gets a bit hot with the fan heating going at the same time.
oh and i had to switch the socket the extension lead was running off after the switch on the double socket stopped working - think something might
have got a bit warm inside and melted it - the other half of the same socket has been holding up so far so good
beware, I've got yellow skin
NS Dev
| posted on 19/4/06 at 01:11 PM |
the way I see it, though dodgy, is actually pretty safe (ducks for cover!!!)
The cable that goes direct from the consumer unit MCB (with RCD protection) is sized correctly for the MCB that protects it, and it runs to a junction
box in the garage, again correctly sized for the MCB protecting it, then to the pair of sockets, all still 45 amp cable. The only weak point is the
sockets. After these the welder cable itself is obviously up to the job, so 1 set of brass contacts is the only part of the system that has its rating
exceeded, and I am very disinclined to use 16 amp blue plugs, 1 cos nothing else I have uses them, 2 cos then I can't use the welder on low
current at somebody elses house and 3 cos the welder will draw over 16 amps anyway so I will exceed the blue plug rating anyway!!!
| posted on 19/4/06 at 02:10 PM |
I had a 140 amp oil cooled arc welder given me and I was a bit dubious about the cable on it so I fitted a new one. I found when I took the plug off
that the fuse was a bolt and when I put the 13 amp fuse in it lasted about 5 minutes so I soldered a piece of 30 amp fuse wire across the fuse.
It's on a 40 amp circuit so it should still blow first (that's my theory anyway) and it works now.
MikeR
| posted on 19/4/06 at 05:48 PM |
Why don't people (i know i'm going to get shot down for this....)
get two fuses or fuse wire and make a fuse that can handle the rating?
The cable was for a top of the range what ever kw (12?) shower even though mine was only 10kw. The sparky who did it commissioned water stations and
the like for a living and liked to "make sure" everything was going to be fine.
Sure it was more a case of "thats all they had in when he went to visit the wholesaler" ...........
907
| posted on 19/4/06 at 06:29 PM |
I have an AC stick welder that can be wired for 3 phase.
On single phase it sometimes blows a 13 amp fuse, but only when I haven't got a spare with me.
I bought one of those cards of fuse wire and made some up using blown 13 amp fuses with a
strand of the 15 amp wire soldered to the outside.
I made half a dozen, but I've only needed the one.
Paul G
caber
| posted on 19/4/06 at 07:37 PM |
HMM Fuse wire is rated to carry double the load for 30 minutes cartridge fuses are "quick blow" and will fail instantly on double the
rated load. 13A plug fuses are supposed to protect the cable and the appliance against a dead short on what can be 5 amp rated cable. Theoretically a
highr rated fuse in a plugtop is OK up to a point. Another possibility is to use two neutral pins in the plug top and forget about the fuse.
A long time ago we used to do this for stage follow spots that drew about 20 amps on starting but ran at about 8 amps, you could never get a cartridge
fuse to survive the start up. This dodge is also used to make convertors from 13A to CEEForm 32A sockets again for connecting stage lighting dimmers
to ring mains . . . .
This is a remarkably effective way of testing for dodgy building wiring . . . . . . .
Caber
Syd Bridge
| posted on 20/4/06 at 08:23 AM |
Couple of nice smaller ac/dc Millers on their website. Same as AlanB bought not so long ago. I've had one for a few years, never a problem (or
rarely) with Miller machines.
Syd.
NS Dev
| posted on 20/4/06 at 02:44 PM |
I gave them a call and the millers are 415v only (single phase but 415v)
but they have a pair of Murex Transtig 200 ACDC machines and an ESAB machine, all useable on 240v single phase and all reasonably priced.
will go over to see them after work one afternoon next week.
