Author: Subject: Grease gun
posted on 7/6/06 at 08:30 AM Reply With Quote
Grease gun
I have an old Draper grease gun - not that great, but it has worked in the past. Now I'm trying to use it to grease my nipples (oooer!) - the ones on the propshaft. Trouble is, it just won't 'click on' to the nipples, so the grease just leaks around the outside.
Have grease nipples changed size over the past 10 years or so? Or am I simply using it the wrong way?
tks
posted on 7/6/06 at 09:25 AM Reply With Quote
mhh
thought this would be the symtom of a blocked niple
does it has the little ball in it?
can you move the ball with something??
tks
posted on 7/6/06 at 11:32 AM Reply With Quote
try pressing really hard on the nipple (ooh err) if the grease gun bit is on flexi hose. then push that hard onto the nipple (ooh err again).
once you start pumpoing (ooh err) the force of the grease pull the small clamsp inside the end piece to hold the inner placcy tube onto the nipple (ooh err).
Works for me.
Use a small pinty thjing to press on the spring loaded ball bearing in the nipple (ooh err) is should give way, if not, it is knackered.
Ferrino
posted on 14/6/06 at 01:12 PM Reply With Quote
I have had a similar problem (brand new nipples so they're not blocked). I can get the jaws to click onto the nipple but the grease still goes everywhere but through the nipple. I've ordered a better quality connector off EBAY for a couple of quid and will see if that works tonight/2mrw.
