jamesbond007ltk
| posted on 17/7/06 at 12:38 PM |
Cortina hub nuts???
What size socket do i need to remove the hub nuts on cortina uprights?
Am changing my discs soon and not near car so want to check i have the correct tools.
Rich
ned
| posted on 17/7/06 at 12:57 PM |
from memory off the top of my head its 22mm, anyone confirm that?
beware, I've got yellow skin
Danozeman
| posted on 17/7/06 at 12:58 PM |
27 i think.
Dan
Avoneer
| posted on 17/7/06 at 04:27 PM |
Yep, I think it's a 27mm too.
Pat...
ned
| posted on 17/7/06 at 06:44 PM |
Thats odd, i didn't think i owned a 27mm socket at the time when i had them apart
Ned.
omega 24 v6
| posted on 17/7/06 at 07:18 PM |
I've just measured my nuts (settle pettal) and I concur 27mm AF.
| posted on 17/7/06 at 07:26 PM |
You shouldn't need a socket as the nut should NEVER be tight. Just tighten until all slack is taken out of bearings then back off the tiniest
amount . Over tightening the nut will cause the bearings to sieze and possibly shear the stub axle . Saw the results of overtight hub nut years ago on
a Ford Anglia. Stub axle sheared and inner bearing friction welded to remains of stub axle .
