TangoMan
| posted on 24/11/06 at 07:52 AM |
Welding Stainless
A bit of advice before I decide how to proceed with my exhaust.
1) Is it possible to weld stainless to mild steel. I ask as I can get a mild stell flange but pipe bends seem easier to source in stainless.
20 If I go the whole lot in stainless, what do I need to weld it, is it just a different wire in the mig from mild steel with a similar technique.
Thanks,
Summer's here!!!!
John Bonnett
| posted on 24/11/06 at 07:56 AM |
Yes stainless can be welded to mild steel and in fact the exhaust flanges on my manifold are mild steel so no problem
John.jpg)
NS Dev
| posted on 24/11/06 at 08:09 AM |
as john says, yes you can weld the two together, best to use stainless wire but mild will work too.
There are all sorts of further details to that statement, but for an exhaust the only one to point out is that the welds will rust slightly, and the
flanges will obviously rust too, so best given a quick splash of VHT paint over the flanges and welds at the flange.
| posted on 24/11/06 at 09:16 AM |
is that bubble wrap over the back side of the alternator? And those ickle individual heat shields
NS Dev
| posted on 24/11/06 at 09:36 AM |
no its aluminium cloth
John Bonnett
| posted on 24/11/06 at 04:54 PM |
quote
Purely cosmetic I'm afraid
John
TangoMan
| posted on 24/11/06 at 06:45 PM |
Thanks for the info.
I will give it a try.
Summer's here!!!!
