andrew-theasby
| posted on 16/2/07 at 11:01 PM |
Press Brake Plans
Hi, has anybody got or know of any plans or sketches of a pressbrake about 4ft wide? Tried google with no luck, plenty of small ones for bending
heavy bar but nothing really suitable for wide bits of thin sheet. probably only really gonna do 2mm ally at the most or thin steel. Drawn up a
little sketch of something i came up with, what do you think? Any improvements?? I arent too sure about the blade, does it have to be a V going into
a V or would my idea of either a round edged flat bar, or a V, going between 2 round bars work, so you could just press it to what ever angle you
want? Any feedbck would be appreciated before i get welding. Thanks
rebelrider
| posted on 16/2/07 at 11:13 PM |
if it helps we have just bought a 70K new one 3meter 150 tonnes i guess not
If you are going to be doing ali for your car i would go with the round bar idea as pushin ali in to a vee scratches it unless you put some kind of
pertection in there.
I use a brake press most days so id be happy to answer any questions youve got.
good luck keep us up dated your plans look like they would work you will change them as you are making it when you realise the support bars are in the
way of the material your folding
| posted on 17/2/07 at 09:02 AM |
You might be better off looking for a sheet folder if you only want to do thin stuff.
http://www.integerspin.co.uk/folder.htm
andrew-theasby
| posted on 17/2/07 at 05:57 PM |
It might end up being something like that, but i prefer the way a press brake can put bends closer together and its a bit more versatile if you want
to bend one end more than the other for example, but thanks for the link. Ill post some piccys when ive got something made..
