speedyxjs
| posted on 23/6/07 at 11:08 AM |
Quick cutting question
Is there any easier way of cutting straight with an angle grinder? I seem to be cutting stange angles when i try and cut 90 degrees. I might just need
more practice.
ps it is fitted with a cutting disk before anyone asks
worX
| posted on 23/6/07 at 11:13 AM |
start off really light or "draw" a line where you are going with the cutting wheel - just touching the surface, then follow that slightly
deeper then you can usually press on ok.
But it pretty much is as you say, just practice!
hth
Wadders
| posted on 23/6/07 at 11:18 AM |
If your cutting flat sheet, try clamping a length of angle or flat bar to it, as a guide for the wheel to run against.
Al.
more practice.
stuart_g
| posted on 23/6/07 at 11:19 AM |
you could buy one of those gismo's that you clamp the angry grinder into, you then have a handle to pull down on.
| posted on 23/6/07 at 11:36 AM |
I usually work on the principle of cutting it roughly to size / shape with the cutting disc then using the grinding disc to get it all schminky
pinky....
mangogrooveworkshop
| posted on 23/6/07 at 12:59 PM |
Ive got a gismo you could take for a tenner and p&p that turns it to a chop saw.
u2 u if you are interested
Be back on line later tonight
mark chandler
| posted on 23/6/07 at 01:42 PM |
I used a hacksaw and vice, just as quick with no mess and accurate. You just need decent blades.
mangogrooveworkshop
| posted on 24/6/07 at 09:18 AM |
Same as this just not as clean
