garage19
| posted on 28/8/07 at 11:30 AM |
Best blasting medium for aluminium?
I want to blast some cast aluminium inlet manifolds and a couple of sumps.
What is the best blast meduim to use?
twybrow
| posted on 28/8/07 at 11:34 AM |
To clean? To remove material? To prep for painting?
garage19
| posted on 28/8/07 at 11:37 AM |
To clean and prep for welding?
Which medium is the most abrasive?
twybrow
| posted on 28/8/07 at 11:38 AM |
http://www.airblast.co.uk/media.html
Olivine looks good.
liam.mccaffrey
| posted on 28/8/07 at 12:04 PM |
ive used old blasting grit in the past with good results
Build Blog
Build Photo Album
andrew-theasby
| posted on 28/8/07 at 01:10 PM |
I use kiln dried sand, but dont breathe in te dust! Cheap as chips and readily available
Confused but excited.
| posted on 28/8/07 at 01:16 PM |
Almost any grit medium.
If you want a fine finish on the manifolds, use glass beads after the grit.
NS Dev
| posted on 31/8/07 at 12:00 PM |
glass bead
