The Baron
| posted on 26/11/07 at 08:11 PM |
Argon Regulator
This might be a dumb question!
I have been having much fun, ‘seriously’ with my group by TIG welder. Up to now I have been using argon shield gas from the MIG welder and gold tip
electrode at a bout 90 amps whilst modifying my pinto sump with half reasonable results.
Now I want to get some 'sexy' row of coins style welds so I need to use pure argon. I intend to start off using some disposable Clarke
bottles (110ltrs) before I shell out on a large bottle of pure argon
Question: - does anyone know where I can get a reasonably priced regulator for a disposable bottle with flow rate control?
Cheers in advance,
The Baron (with singed knuckles)
NS Dev
| posted on 26/11/07 at 08:14 PM |
don't worry about it, if you are going to go to a proper bottle in the not too distant future then just set it by noise on the std little
regulator.
caber
| posted on 26/11/07 at 08:25 PM |
for the amount of money you will spend on little bottles and a reg you could get a big bottle from Air Products with a built in regulator! You get a
specific flow regulator connection for your hose I went for 11 lpm and this is fine with a bit of tweaking on the torchvalve. If you are going to end
up doing a serious amount of welding i.e a locost worth just get a big bottle! I am on my third in two years having done the locost and a bit of other
welding including Land Rover bits and two sills on a Triumph Herald!
Caber
oadamo
| posted on 26/11/07 at 08:27 PM |
machine mart i think there £8-9.
adam
Mansfield
| posted on 26/11/07 at 09:21 PM |
Machine mart cheapies can be very poor. I had to cut off the plastic bit with the scale to get it to work properly. That was the third one I had
from them, the forst two did nothing at all.
madteg
| posted on 26/11/07 at 09:57 PM |
gas
The gas you want from B O C is called argonshield (light) and from air products is called (cougar). Hope this helps kev.
| posted on 26/11/07 at 11:48 PM |
Argoshield and Coogar are mig gas, you need pure argon for tig. I don't understand how you have tig welded with Argoshield without burning your
tungsten away, it sounds like you have invented a new process
[Edited on 26/11/07 by Peteff]
mad-butcher
| posted on 27/11/07 at 07:11 PM |
Pete
That's the impression I was under but just tried it today on 86% argon mix not exellent results but the tips still in one piece
Tony
