eccsmk
| posted on 16/12/07 at 05:10 PM |
battery charger recomendations
as above really mine gave up about 10 mins ago!
| posted on 16/12/07 at 05:31 PM |
Lidl have a nice small fully automatic charger in just now --- not high output (istr 5 amps max ) but fully automatic with a maintanance float charge
facility.
eccsmk
| posted on 16/12/07 at 05:39 PM |
sounding good might have to take a ride over tomorrow
MkIndy7
| posted on 16/12/07 at 06:04 PM |
I'd second the above,
But if its the plug top type one with 2 crocodile clips coming off its excellent for maintainance charges etc but not so good for quickly charging
batteries.
I put mine on the other night when the car wouldn't start and it still wouldn't start 12 hours later.
So for that case you might be better off with a bigger battery charger that also does the maintanance function, depends what you wan't really.
roadrunner
| posted on 16/12/07 at 07:14 PM |
I also have that Lidl one , very handy IMHO, when the tin top battery's flat, just a quick twenty minuets and she will start first time, i think
they are £12.
bonzoronnie
posted on 16/12/07 at 07:16 PM |
Chargers
Halfords do a very good range of auto chargers.
Machine mart also do a good range.
Probably a better option's than a Ching-Chong, Fleabay one.
Ronnie
eccsmk
| posted on 16/12/07 at 07:20 PM |
going out to see what i cant find tomorrow especially as my angle grinder just caught fire in my hand the scary thing is i only bought it 5 hours
ago!!!! thanks b&q
bonzoronnie
posted on 16/12/07 at 08:17 PM |
Bad days
Dont you just hate days like that
You wern't trying to cut a bit of 4 inch solid bar at the time
Go on spill the beans. we wont tell B&Q, Honest
Ronnie
| posted on 16/12/07 at 08:30 PM |
mine has a fuse fitted to the underside - have you checkey there is no fuse blown?
the electrics inside are fairly simple so unless the trasnformer goes, they should be faily easy to fix.
I have a cheap 6/12 V charger from argos boughyt a few years ago.
IMO if you need to use one regulalry, then you should invsest in a new battery so a cheap one should be more than adequate for the odd monthly top
up.
eccsmk
| posted on 17/12/07 at 02:16 PM |
lunch time so quick reply the charger is burned out inside no idea why
the disk cutter was cleaning some rust off so i could weld seems it was a common fault trading standards anyone lol
| posted on 17/12/07 at 04:17 PM |
The fan sucks metal grindings back into the motor and burns it out. Aim them away from the front of the blade and they might last longer.
eccsmk
| posted on 17/12/07 at 04:54 PM |
i doubt this one had chance to suck much in but i'll take that into account when i get a decent grinder
thanks
