I know how the readyboost works (use the space on a usb stick etc as a pagefile/virtual memory) but I was mildly surprised to find the option on a SD
card... It did say, however, that the card wasn't fast enough to boost performance. Then it hit me, there's high speed ones (for HD video
capture and such iirc) I wonder if they're fast enough. This is of course provided I can find one cheaper than a normal ram upgrade mind...
Anyone think it would be worth it?
Thanks in advance
Having used it on a few pc's....I'd say it's pretty useless. RAM is very cheap these days and in my opinion there's no substitute for it!
what kind of RAM do you need ?
(I've got loads of old stuff and some newer ones dowing nowt here)
if your using a 32 bit machine it could give a small benefit as your limited to 4GB ram anyway (less if on XP, though it will still report 4GB).
this 4GB limit applies to the flashdrive your using as well if i remember correctly (on 32bit machines)
Fair dos, just thought it was an idea. The ram I'd need is DDR2 PC2-5300 at 333mhz DDR2 667. I think last time I looked 4Gb was about £50... No idea if I can go better or faster that's what's in there now in a single gigabyte flavour
(someone took my last ones a few weeks back)
