Well, I finally felt like I got my new hobby to a point of putting out there for the world. I've been teaching myself CSS and ASP .NET lately
and felt that I should combine two of my other hobbies to help. So I present....
Auto-Math-Geek
Please offer up any comments and/or advice/criticisms for me. I'm always up for making improvements. I'm not much on creating the style of
a web site so I feel that is where I need most of the help. I do know that the "real world" development environment purposefully keeps the
data away from the style so that is what I tried emulate as I built the site. There are only a couple of functional pages available now, but
I'll be starting the other sections in the next few days. A little hard to do with only 90 minutes a day during the week, but I figured I would
make my lunches useful.
Anyway.... everyone, get your knives out and dice away.
Beags
i broke it already
Server Error in '/' Application.
Value cannot be null.
Parameter name: row
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about
the error and where it originated in the code.
Exception Details: System.ArgumentNullException: Value cannot be null.
Parameter name: row
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception
can be identified using the exception stack trace below.
Stack Trace:
[ArgumentNullException: Value cannot be null.
Parameter name: row]
System.Data.DataRowExtensions.Field(DataRow row, String columnName) +23463
beagley.BasicFormulas.Pages.FormulasBasic.dropdownlist_engine_selector_SelectedIndexChanged(Object sender, EventArgs e) in C
ocuments and
SettingsAdministratorMy DocumentsVisual Studio 2010ProjectsbeagleybeagleyPagesStandardFormulasFormulasBasic.aspx.cs:175
System.Web.UI.WebControls.ListControl.OnSelectedIndexChanged(EventArgs e) +118
System.Web.UI.WebControls.DropDownList.RaisePostDataChangedEvent() +143
System.Web.UI.WebControls.DropDownList.System.Web.UI.IPostBackDataHandler.RaisePostDataChangedEvent() +10
System.Web.UI.Page.RaiseChangedEvents() +134
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5201
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.272
all i did was went to basic formulas, selected engine (2.0 duratec) and saw it filled in some info, but i didn't want that info, so i selected
'select an engine' and went to chage the bore figure, and got the message above
edit: and now i've gone through for 86x86 tried changine bore to 87, it won't give me any answers to anything now.
I like it though, i'd never have thought a piston would travel at 19 meters per second, so theres some fascinating stuff in there (and i've
only seen a tiny bit) but it is quite glitchy
[Edited on 9/5/12 by blakep82]
A good one on there to have would be trumpet length calculator so you can see how many times you get the optimum torque/power from the pulse wave effect!
As far as 'style' and a 'proffesional look' it looks spot on to me, good work!
^^^ Second that. Really clean and professional look to it.
I'd get the folks on here to give you ideas for equations - that'll keep you busy to 2064...
Originally posted by blakep82
i broke it already![]()
all i did was went to basic formulas, selected engine (2.0 duratec) and saw it filled in some info, but i didn't want that info, so i selected 'select an engine' and went to chage the bore figure, and got the message above
I like it though, i'd never have thought a piston would travel at 19 meters per second, so theres some fascinating stuff in there (and i've only seen a tiny bit) but it is quite glitchy
Thanks for your input. quote:
My goal is to programmatically build a graphic of the sine waves for the piston's
position, velocity, and acceleration based on those parameters. Looks good to me.
Got me thinking that with 64 bit windows now being common place, the good old gearcalc program is more and more difficult to run. How about a web page
to do he same?
Originally posted by Xtreme Kermit
Looks good to me.
Got me thinking that with 64 bit windows now being common place, the good old gearcalc program is more and more difficult to run. How about a web page to do he same?
as above, it's crisp and clean. not had too much of a play but one thing i noticed was your contact page - could do with a proper contact form?
