need to find a new broadband provider
i have had a look at this evolution broadband link above, is chris envolved with them or are they just sponsers
recomendations anyone, i have used pipex before but apparantly they only provide a 1 meg connection in this area, and i have a 2meg now with BT
just checked this out and apparantly BT also think i can only recieve 1 meg?? weird
[Edited on 6/12/05 by liam.mccaffrey]
AOL Broadband and range of services is good but the customer service is appaling. Basic BB is £17.99 per month with no download limits.
Try NTL Broardband,
Its run our computers with no problem.
I had a a similar experience it the line tester provided by BT applet that every provide uses hasn't been updated. My inderstanding is anyone who
had 512 working with the original ADSL roll out should be OK on 2meg Just order and see what happens.
One thing that can improve you chances of working at a higher speed especially if you live in house with older telephone wiring is to fit a filtered
face plate to the house master socket and seperate ADSL and voice where they come into the house rather than fit filters to the voice extensions
see
http://www.solwise.co.uk/adsl_splitters.htm
what also helps an really lot is..
an sepparate program on you pc wich limits your downloading speed..
because this will smooth your internet speed out..and will take away work from the limiting server of your ISP...
the problem is that that pc needs to cut thousands of pc's and that results in an to big off time wich means lost speed
Tks
if any tech talk is needed i will hear
www.adsl4less.com
Been with them for the past 2 years. Never had any problems really, compared to other people I know who are on AOL, NTL, BT etc etc/
They are also fcuking cheap! 2mb broadband for £11.99/month.
Sorry to contradict you, but it isn't the case if you recieve 512K ADSL, you can get 2Mb. It is all to do with how far you are away from your
local exchange, the further you are away, the slower the ADSL is. I'm on the upper limit of the distance (which is 5 or 6 Km) and although my
ISP (Demon) recently upgraded all their Home customers to 2Mb, my line is only stable at 1Mb, so thats what I got.
The ADSL Checker from BT. isn't always accurate, but it is mainly due to the fact, that when you are out at the limits of the ADSL range, it is
difficult for the checker to accurately measure your line length , and sometimes with a little fiddling, and maybe re-routing of your line they can
get higher speeds out of it. If your within 4km of your exchange, they can all but guarantee you can get 2mb. If your between 4 and 6km you will get
a speed between 512, 1Mb or 2Mb, and it will depend on the results of the 'whoosh' test that checks the noise on your line.
Originally posted by britishtrident
I had a a similar experience it the line tester provided by BT applet that every provide uses hasn't been updated. My inderstanding is anyone who had 512 working with the original ADSL roll out should be OK on 2meg Just order and see what happens.
One thing that can improve you chances of working at a higher speed especially if you live in house with older telephone wiring is to fit a filtered face plate to the house master socket and seperate ADSL and voice where they come into the house rather than fit filters to the voice extensions see
dunno if it helps but AOL basically paid NTL to let them use their lines/servers blah blah, and since AOL just takes to your PC like flys round dog dirt NTL is the one to go for over the 2 of them, but im sure someone else on here can suggest a better one than NTL (tho i use NTL and have had no problems and been using it for over 2 years)
have a look at www.adslguide.co.uk i used to be with eclispe and they are by far the best for customer service and i have used quite a few suppliers.
Not seen the .co.uk one but here's another guide site which I've used to good effect http://www.adslguide.org.uk/. You
can pick a number of different providers and compare them based on the test results of their users doing speed tests and rating them.
FWIW, I'm with Freedom2Surf and they usually come out on top as far as speed is concerned. Customer
service is pretty good too having needed to query a billing issue not so long ago. They get my vote and aren't too bad on price if you choose
one of the limited download packages.
Hi
I have been with www.e7even.com for over a year now. Very good service and extremely competitive pricing but to get it you pay in advance. 1meg
currently equivalent to £13 / month. Worth a look as they often run special offers like free set up and modems.
snip
[Edited on 6/12/05 by phoenix70]
AOL isn't really an ISP more like a nasty hijack of your computer. Best to stick to a plain vanilla ISPS that stick to industry standards and don't bombard you with screenfuls of clutter.
I took out Bulldog as they were low speed compared to the others and replaced with Freedom2Surf. Looks like it'd be a toss up between them and
Zen.
I'd fully recommend Zen Internet. They cost a bit more but it is money well spent if you use your broadband a lot. They have also just won the PC
Pro ISP award again this year. They have no plans to introduce the throttling or capping which other ISP's have recently introduced so you get
100% of what you pay for.
I hope this helps,
Craig.
www.adsl4less.com
On the £12 package there is a download limit of 2Gb per month, which is enough for most people who just surf the net (It works out at around 4 hours
per day). Each extra Gb is £1.75.
The unlimited download (and I mean unlimited, we had over 200Gb one month) service at 2Mb is £35 and 1Mb is £25.
No contract on any of their services.
We are on 1Mb here and are getting 1.1Mb
