Hi All,
I need a little advice on CPU upgrading if anyone can help or point me to a website that can help.
I am looking to upgrade my 1.1 Ghz Socket 478 for a 2+ Ghz. My questions are:
1. Do I need to match the 400 MHz specification given in the motherboard handbook?
2. Is the process of changing the processor easy enough and should I buy a heat sink and fan as well to make it easier?
3. Is there anything else I need to consider?
If anyone can help, many thanks.
RPS
Hi there, could you list the make and model number of your current motherboard.
Also you may be interested in
this little
offer
Hi,
The Motherboard is a P4 Titan GA-8ILMT4 (Intel 845GL chipset).
Looks a tempting offer, but I rather not change the whole lot at the moment if I don't have to.
Thanks,
RPS
Well, here is a list of CPUs your board should
support according to Gigabyte themselfs
EDIT:
Oh and as for heatsinks and fans if you buy the CPU retail packs they should come with a new one for that CPU.
[Edited on 28-12-05 by CommanderAce]
Originally posted by RPS
Hi All,
RPS
This one would be good, has a 512kb cache
http://cgi.ebay.co.uk/Pentium-4-2-6-Ghz-CPU-Socket-478-400-FSB_W0QQitemZ6830121859QQcategoryZ14293QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or this
http://cgi.ebay.co.uk/P4-2-8Ghz-Socket-478-CPU-400-FSB_W0QQitemZ6834307567QQcategoryZ14293QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or this
http://cgi.ebay.co.uk/P4-2-4Ghz-Socket-478-CPU-400-FSB_W0QQitemZ6834307950QQcategoryZ14293QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
All available 400fsb Pentium 4 processors over 2ghz
[Edited on 28-12-05 by zzrpowerd-locost]
And the mobile ones, note the l2 cache size
Are you 100000% sure its a P4 motherboard?
Intel never made a 1.1GHz P4 (not according to my memory, or their website) but they did do that in a Celeron and P3, socket 370.
May be worth checking the POST screen to be certain of the motherboard before buying anything.
[Edited on 28/12/05 by the_fbi]
they did but it werent a socket 478, it was a 479
I have just checked and the CPU is a 1.1, but it is a AMD Duron. Does this makes sense?
Thanks for all the help.
RPS
That makes a lot more sense!
It does however mean the motherboard model you indicated, isn't correct.
Thanks Guys, you saved me a lot of money. I took the cover off the PC and the actual Motherboard is different to the MB handbook I was given with
the computer. Funny thing is, I used the wrong model number to get the RAM memory when I upgraded that and it worked just fine!
Thanks,
RPS
