Hi Guys,
Puter won't boot.
Will start, beep , then beep, then beep and keep on beeping about every 5 seconds and that's as far as it gets.
Took out both (what I think are) memory cards from the board.
See following pics:
And the other one:
With Pic 1 in either slot, the computer will boot and run fine, albeit slowly and with no beep on start up.
With Pic 2 in any slot either on it's own or with Pic 1, I get the same beep scenario and a non starting computer.
Do I just need some new memory and is it plug and play?
Thanks,
Pat.
As far as I can tell from the pics you have two sticks of SDRAM. One is 128Mb and one is 64Mb. The 128Mb is PC133 and the 64Mb is PC100. Assuming I am
correct the cheapest option will be to buy another stick of 128Mb SDRAM PC133 which will cost very little and throw away the faulty 64Mb stick.
Here's a cheap source:
http://ebuyer.com/UK/product/19820/rb/22360263301
Although if it was my computer I may be tempted to buy 2 x 256 sticks and it will run a little faster.
How many slots have you got and are they all the same. If you have room you can reuse your working stick with your new memory.
It's not my computer and it has two slots.
Any reason why it doens't beep with just the working 128 memory?
Works fine though.
Pat...
They are the "beep codes" your getting telling you there is a problem...
http://www.pchell.com/hardware/beepcodes.shtml
So sticking in a new memory stick should re-gain my beep?
Pat...
Works fine though.
Pat...
No, it won't be running at full tilt.
It works fine as it is with just the 128 stick, but with no beep.
Is it ok to leave it as it is even though there is no beep, or is it beeping because it needs a 2nd stick of whatever size?
Pat.
With no beep and working is fine.
The multiple beeps are becuase its doing a test of the 64mb memory stick and finding an error.
If the PC doesn't act too sluggish I would leave it as is.
As you have found out the memory doesn't need to be matched pairs on your PC
