carlgeldard
| posted on 8/10/06 at 04:01 PM |
Getting data from crashed old hard drive
My computer crashed on Friday night and it does very little other than a black screen. It will not even accept the recovery disks. Is there anyway of
connecting this new machine to the old one to retrive all the data that i do not have on back up.
Cheers Carl
iank
| posted on 8/10/06 at 04:12 PM |
If the disk is OK (reasonable chance - it sounds like a PSU/motherboard problem) the disk can be plugged into another computer to get the data out -
if there isn't a spare connector you can put it in place of the CDROM drive (you will probably have to switch the jumper on the back to
slave)
If the disk is broken then for a big pile of cash there are specialist companies that can recover most of the data, but it usually isn't worth
it for individuals.
| posted on 8/10/06 at 05:34 PM |
Does the motherboard POST beep?
If it doesn't spin up you have shot it. Data recovery firms charge an absolute fortune so unless your stuff is invaluable just write it off. If
it's the drive you should still get something till the motherboard doesn't find an operating system.
| posted on 8/10/06 at 06:00 PM |
Carl,
Connect to another PC as a slave - if DOS recognises it as a slave, back up the old data. If not... bad news, your data is practically useless. You
can appoint a specialist to try to retrieve the data but it's VERY expensive (I've seen some at £180/hour) and they do not guarantee full
data recovery - sorry!
Avoneer
| posted on 8/10/06 at 08:48 PM |
Carl,
Take your HD out and fetch it round and I'll see if there's owt on it I can recover.
Pat...
| posted on 9/10/06 at 07:29 AM |
I've just bought one of these things
CLICKY
Lets you plug a hard drive or CD/DVD drive into a USB socket. Seems to work very well - we use one in the office for jobs just like this. Might be an
easy way to plug a suspect hard drive into a good PC.
(Only down-side - it costs < £10, but P&P is > £6 !)
mackei23b
| posted on 9/10/06 at 07:44 AM |
There is also some software that will let you recover data if the drive is corrupt.
Ian
carlgeldard
| posted on 9/10/06 at 05:26 PM |
Cheers guys
I might buy one of those David. Pat I will be in touch.
Thanks again Carl
