Author: Subject: half life cheat problem
macspeedy
posted on 15/6/04 at 07:18 PM Reply With Quote
having played and deleted half life i have re installed it
and i am having problems getting the cheayts to work can anyone advise?
macspeedy
posted on 15/6/04 at 07:56 PM Reply With Quote
when i try and get the ~ to activate the console it doesn't? tried all sorts of variations but not the right one
Mark Allanson
posted on 15/6/04 at 08:06 PM Reply With Quote
by Luke Allanson:
Right click on your half life shortcut, and click properties, in the command line specifying where the .exe files is located, add the following:
-dev -console
click apply, then ok
open up half life, and start a new game, now the ` (key under esc) key, should open up the console.
typing
god
in the console will activate invulnerablility
typing
noclip
in the console will make the player fly through walls, floors, and generally explore the level (useful if you get stuck in something)
There are more but i cant remember them.
Mark Allanson
posted on 15/6/04 at 08:07 PM Reply With Quote
by Mark Allanson:
I knew he would be useful one day!!!
macspeedy
posted on 15/6/04 at 08:09 PM Reply With Quote
cheers!!!!!!!!!!
all the cheats on the web said press ~ to bring down console been at that for ages
N*E*R*D
posted on 15/6/04 at 08:36 PM Reply With Quote
Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat!
Y you need to cheat at half-life it is so easy anyhow
but some of the best cheats are the openGL ones that let you see through walls
i hate campeing FU*KTARDS
JL
"Good Bad I'm the guy with the gun"
mangogrooveworkshop
posted on 16/6/04 at 06:12 PM Reply With Quote
Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat!Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat! Cheat ! Cheat! Cheat!LOL
I will let you loose on the quad again! OUCH OUCH OUCH OUCHOUCH OUCH OUCH OUCHOUCH OUCH OUCH OUCHOUCH OUCH OUCH OUCHOUCH OUCH OUCH OUCHOUCH OUCH OUCH OUCHOUCH OUCH OUCH OUCHOUCH OUCH OUCH OUCH!!!
macspeedy
posted on 16/6/04 at 06:24 PM Reply With Quote
last time did most of it without cheats, adds to the gore factor!
