Alan B
| posted on 19/9/11 at 11:15 PM |
Floating licences...simple explanation needed
I may be working with a new customer who uses SolidWorks 2011 whereas I'm on SW 2008. He reckons it should be no problem...he will install it on
my machine and when I go to use it will contact Solidworks and if there are spare licences available I will be able to use it.
Is it really that simple?.....bearing in mind I won't be on his network.........seems too easy, logical and sensible.
Alan
bmseven
| posted on 20/9/11 at 06:38 AM |
I would have thought you would need to be on the same network to recieve a license
Solidworks Licensing
BMW 7 Resource
Bures Pit anyone?
HowardB
| posted on 20/9/11 at 06:55 AM |
you can borrow licences from the server, but then that licence is not available for anyone else,...
hth
Howard
balidey
| posted on 20/9/11 at 07:29 AM |
This will only be possible if the company you are getting the licence from has a Network Licence set up on their account. Its something like £1200 to
convert standard to network. If this has been done then yes you can migrate a licence off it, but you will need initial connection to the server that
their program is installed on.
Just gone through this process at my work.
Dutch bears have terrible skin due to their clogged paws
HowardB
| posted on 20/9/11 at 08:25 AM |
we have too, adds a bit of flexibility for home working too
Howard
Alan B
| posted on 20/9/11 at 10:04 AM |
Thanks guys....clears things up a bit...the customer did mention bringing my PC in his place so that may be it.
Cheers, Alan
