Blackbird Rush
| posted on 30/8/12 at 06:00 PM |
Monitor died
Hi All
I have a samsung syncmaster 226CW used as a 2nd monitor on my laptop, all of a sudden its just died no warning just went blank and no life at all
Had a google and thought it may be the PSU capacitors they look OK i.e. no bulging.
Any ideas or bin it, had it a couple of years and it was 2nd hand when i got it.
Ta for any help.
Ash
bi22le
| posted on 30/8/12 at 06:52 PM |
Fuse in the plug?
Dont laugh, we have all jumped in at the deep end and expected the worse for no reason!!!
Please read my ring story:
balidey
| posted on 30/8/12 at 07:20 PM |
or kicked the VGA cable out the back of the PC
Dutch bears have terrible skin due to their clogged paws
gremlin1234
| posted on 30/8/12 at 09:48 PM |
probably will be the psu capacitors,
but also maybe the back-light, is there any trace of an image, (use a very bright torch to look)
does the power light come on at all?
Blackbird Rush
| posted on 30/8/12 at 10:26 PM |
Hi
Have tried a different lead i know works...... nothing
There is no life whatsoever no power on lights etc....
maybe try and get hold of some replacement caps then (nothing to loose!)
Ash.
Surrey Dave
| posted on 31/8/12 at 07:29 AM |
Worth a go
I've been lucky with a monitor and a Samsung 37" tv changing capicitors, so may be worth a go , ebay is an easy place to get the parts.
Sometimes kits are listed for a particular monitor (usually Samsung)
Blackbird Rush
| posted on 1/10/12 at 06:49 PM |
Getting round to fixing this , popped by maplin to get some caps , they didn't have an 820 mf cap only a 1000 mf one.
How important with caps is it to get an identical one?
Ash
gremlin1234
| posted on 1/10/12 at 07:08 PM |
best to try and get the same rating, and certainly the same construction. - only replace electrolytics with new electrolytics
though generally +100% / -50% might/should work.
the voltage rating however must not be less than you currently have, but it would be fine to replace 16v rated ones with anything above (say
25v ) though higher voltage ones tend to be larger.
