Rorty
| posted on 16/6/05 at 08:37 AM |
Torrent contents.
I downloaded some torrents which contain files that I don't know how to deal with; one has the extension .iso and the other is called
Serial.nfo.
I presume the Serial.nfo contains the serial, but which program do I use to open it?
How the hell do I open/install the .iso files? I read somewhere I have to burn them to disc then do two somersaults and open them in another drive
...or something similar.
Any help would be appreciated.
Cheers, Rorty.
Danozeman
| posted on 16/6/05 at 08:42 AM |
IIRC the .iso is a file created with nero etc as an image of a film etc. They have to be put back cd to open. Nero will write them. I think it tells
u about them in the nero help thing. If not do a search on google for iso files. I found a site that tells you how to use them.
The .nfo is an info file i think. It will open in a strange way using xp in internet explorer...
I had loads of these when i was downloading some dvd's
[Edited on 16/6/05 by Danozeman]
Dan
Dillinger1977
| posted on 16/6/05 at 08:56 AM |
the NFO is just plain text usually. notepad will do it. (open notepad, and drag and drop the file into it)
-Rog
phelpsa
| posted on 16/6/05 at 09:47 AM |
Don't just burn the ISO to a disc using XP cd burning software, you must use an image burning software (like Nero).
Adam
ned
| posted on 16/6/05 at 09:56 AM |
.iso is an image of a cd, use a burning prog such as easy cd creator or nero to burn it onto a disc..
beware, I've got yellow skin
splitrivet
| posted on 16/6/05 at 10:06 AM |
Easy, open nero, click copy and back up, click burn image to disc add files, off you go.
Aint got a clue with other burning software, Nero is the dogs and dead easy to use,open the NFO with wordpad if your using XP.
Bob
Rorty
| posted on 16/6/05 at 12:36 PM |
Thanks all. I'm off to bed now, but I'll give it a go in the morning and report back here if I have any problems.
Cheers, Rorty.
chrism
| posted on 16/6/05 at 03:53 PM |
I have a piece of free software called Virtual DAEMON Manager which lets you load image files as a Virtual CD drive so you don't have to burn it
to disc.
Its usefull for testing downloads before wasting discs.
A little hard work never killed anyone, but why take the risk!
jonno
| posted on 16/6/05 at 05:03 PM |
Alcohol 120 use's a virtual drive as well u just mount the iso, and browse or install from that if you do not want to burn it.Use notepad to
open your nfo file Sure u can find alcohol 120 from your torrent site
Rorty
posted on 16/6/05 at 11:21 PM |
Nero is indeed the dog's danglies!
I've also downloaded Alcohol 120% for a bit of a look see ...thanks Jonno.
I have a further query though; how do I access files with the .bin and .cue extensions?
Cheers, Rorty.
| posted on 17/6/05 at 01:31 AM |
Rorty - using Nero
Go to copy and backup section. Click on 'Burn image to disc'
place bin file into directory. the other gets accessed by it and writes as a proper ISO disc or DVD
Rorty
| posted on 17/6/05 at 02:24 AM |
Beaut! Thanks Hellfire.
Cheers, Rorty.
Richard Y
| posted on 17/6/05 at 06:47 AM |
get a program called daemon tools this will mount any image as if you had a virtual cd rom drive then open the image file as if it was a cd rom drive
remove the contents eg: vob files if its a dvd then use nero dvd video creator say for instance to burn it back that way you truely can use nero for
all image file formats
jonno
| posted on 17/6/05 at 05:57 PM |
Alcohol 120 also deals with .bin and .cue extensions as well, u can browse or burn ... does sound a bit like Virtual DAEMON Manager as Chrism is on
about.
