ady8077
| posted on 23/7/05 at 05:55 PM |
XP not shutting down
Hi my pc's stopped switching off, after clicking turn off, it starts unloading and gets to the " windows is saving your settings "
and that’s it. Any suggestions
Adrian
Mark Allanson
| posted on 23/7/05 at 06:47 PM |
I had the same thing with 2000 pro, it was norton trying to virus check stuff that did not exist
andy d (rizla)
| posted on 23/7/05 at 06:52 PM |
some modern computers have a button on the case that helps in these situatios
or failing that throw the master switch usualy near the skirting board
| posted on 23/7/05 at 07:05 PM |
Now you're just getting technical...
DJ
| posted on 23/7/05 at 07:10 PM |
Either it is a badly behaved process or program running in the back ground could be either one you have installed or virus/malware you have picked
up.
First thing to to is bring up the task manager and indenify what proess and programs are running in th background, after that try a virus sweep and
run HijackThis and examine the log file it produces.
[Edited on 23/7/05 by britishtrident]
jestre
| posted on 23/7/05 at 10:51 PM |
as a tech, I recommend a full spyware scan
ady8077
| posted on 24/7/05 at 11:51 AM |
The button on the case doesn't switch it off
And i'm fed up crawling under the desk to turn the plug off
I've ran adaware and spybot, didn't find anything, i'll try hijack this next
Adrian
pbura
| posted on 24/7/05 at 12:02 PM |
Did that to a client's computer and it trashed the boot record
Pete
| posted on 24/7/05 at 01:43 PM |
The button usually has a delay on it so you don't shut it down accidentally. You can set the option to have it shut down or hibernate in the
bios. Keep your finger on it for about 5 seconds and see if that shuts it down.
[Edited on 24/7/05 by Peteff]
