DorsetStrider
| posted on 26/1/06 at 12:04 PM |
SATA HELP......PPPPLEEEASSE!
Hiya guys.
I used to have an asrock mother board and AMD CPU with an IDE HDD on which was installed windows etc. It also had a SATA drive that I used to store
all my documents etc for backup purposes.
Then I foolishly upgraded to a asrock k8nf4g-sata2 motherboard and AMD semipron 3000+ CPU. Done a fresh install of window's XP on the IDE
drive... everything going smoothly so far. THAT'S when I discovered the problem. despite trying every driver I can find I cannot get
window's to recognise the SATA drive. When I run the add hardware wizard it finds it and tells me to install drivers (which I do) it then says
"you're new hardware may not run properly until you reboot blah blah) reboot and guess what??? No SATA drive.
Can anyone help me out with this as if push comes to shove I'll have to downgrade back to the original motherboard + CPU as there is stuff on
the SATA drive that is both irriplaceable and needed.
Thanks in advance.
Who the f**K tightened this up!
Scotty
| posted on 26/1/06 at 12:15 PM |
if windows is finding it, then i would suggest you havent got the right drivers - check the asrock web site for updated drivers
is the hard drive a sata 2 drive - might be worth trying jumpering the drive back to sata 1 (had a similar problem myself)
PLEASE NOTE! All comments made by this person are to be considered "Tongue in Cheek" and are not meant to be taken seriously in any way - so there!
Scotty
| posted on 26/1/06 at 12:16 PM |
ps - i assume that the bios screen finds the drive (on boot)
Scotty
| posted on 26/1/06 at 12:18 PM |
according to the asrock web site the last bios update was may 2005 - you will probably have that version
whoops mis-read that its actually 5th.dec, 2005 - if the bios not finding it - might be worth flashing bios
[Edited on 26/1/06 by Scotty]
flak monkey
| posted on 26/1/06 at 12:42 PM |
Go into the bios (hit del when booting). Go into the integrated peripherals section and chack that SATA IDE is turned on (on most boards the default
is off!)
Very very few drives or new motherboards need the drivers installing during the windows install. Certainly none that I have ever done.
Sera
http://www.motosera.com
muzchap
| posted on 26/1/06 at 12:45 PM |
If windows is recognising it and prompting for drivers then
a) contact the motherboard vendor
b) check the drive manfucturers website for advice
It certainly should find it.
Have you tried going into Start--->Control Panel--->Administrative Tools--->Computer Management
Then under STORAGE click Disc Management.
If you see the SATA drive listed - right click on it - make active and assign a DRIVE LETTER.
Then it should be visible
Good luck!
donny
| posted on 26/1/06 at 03:27 PM |
I built a pc last year and had a similar problem with the motherboard (ASUS a8n) not noticing the sata hard drives. I had to use a program called
'disk wizard' to create a floppy disk install utility. Mine Sata drives are from seagate. The guide and software is available on their
website - http://www.seagate.com/support/kb/disc/howto/sata_install_tshoot.html
After running the utility program from the floppy drive windows xp should recognise your hard drive.
Donny.
rusty
| posted on 26/1/06 at 04:12 PM |
If the drive is not being picked up in the bios then it will not be picked up in windows.
If it is not picking it up in the bios first thing to do it try and jumper the drive. I should say on top of the drive which jumper you need to use.
It might say something like force SATA 150
UncleFista
| posted on 26/1/06 at 05:30 PM |
Not "really" much of a help, but I had to click on the thread 'cos I read it as "SANTA HELP......PPPPLEEEASSE!"
I'll get me coat....
Tony Bond / UncleFista
DorsetStrider
| posted on 26/1/06 at 08:04 PM |
Hiya guys.
Thanks for your help. I finally got it working, it was a problem with the BIO settings (although god know's which one)
SOOOO....
The winner of the chocolate banana is.....
drumroll.....
A joint winner between Flak Monkey and Scotty..... come and collect your prize guys.
And the crowd go wild, a very popular decision for the judges there!
(yes I know......I'm booked in to the psychatric clinic on monday)
flak monkey
| posted on 26/1/06 at 08:19 PM |
What do I win?
Glad you got it sorted
Sera
Scotty
| posted on 27/1/06 at 08:50 AM |
I don't mind coming second - as all gentlemen do !!!
ask the wife
DorsetStrider
| posted on 27/1/06 at 09:26 AM |
Ok on reviewing slow motion play back the ref has awarded everyone with a goal, slightly to the annoyance of FIFA who now have to make 103 extra world
cups!
A great day ladies and gentlemen.
Scotty
| posted on 27/1/06 at 10:31 AM |
you sound a happy person
what drugs do you use ???
DorsetStrider
| posted on 27/1/06 at 10:36 AM |
High on life mate.....
That is to say that if I keep telling myself that sooner or later I might start to believe it.
paulbeyer
| posted on 19/2/06 at 10:50 PM |
If he's booked into the Psychiatric clinic on Monday my guess is Olanzapine.
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
