mac1ZR
| posted on 26/1/06 at 07:27 PM |
RAM problem
Hi, I was given a PC today,worked fine. I tried installing another stick of DDR ram and now it turns on,but nothing will happen-the screen stays on
standby.I've tried it with just the original ram,and just the new stick,and with both,but still nothing. Have I blown both sticks of ram or
worse?thanks
flak monkey
| posted on 26/1/06 at 07:33 PM |
Umm...
Are you sure the RAM is right down in the slot in the motherboard? DDR is a rather tight fit and you need to make sure the little latches are latched
into the edge of the RAM properly.
Do you get any beeps from the motherboard when you press the power button?
Is the main case responding at all, i.e. is it turning on at all?
Sera
http://www.motosera.com
mac1ZR
| posted on 26/1/06 at 07:52 PM |
all sorted now,turns out the previous owner said you have to keep pressing the restart button over and over until it boots!thnaks ne way.
