Jasper
| posted on 26/9/06 at 11:33 AM |
More computer trouble
I have set everything on my PC to allow me access to all files and folders, whether they are hidden or otherwise.
Yet it wouldn't let me into certain folders now and it's driing me nuts.
Trying to get into Documents and Settings/All USers/Documents. Keeps saying access is denied....
ned
| posted on 26/9/06 at 11:52 AM |
are you logged in with an account with admin priveleges?
beware, I've got yellow skin
tks
| posted on 26/9/06 at 12:45 PM |
Ok,
wich OS?
if its XP
you need to map the drive to your remote pc..
sow iv a share on A = called ShareC
then on PC B you do:
net use z: \\A\sharec /user username) (passw)
easy as dell!
Tks
for more help type net use /?
to use this you need to go to the command prompt
by typeing cmd in the execute box
Jasper
| posted on 26/9/06 at 01:55 PM |
quote: Originally posted by tks
wich OS?
if its XP
net use z: \Asharec /user username) (passw)
easy as dell!
Tks
Thanks for the help - but I understood absolutely none of that
And yes Ned, logged in full full admin privileges
Now decided to just do a system restore from by Back-Up HDD after spending nearly the whole day on this now.....
Jasper
| posted on 26/9/06 at 04:09 PM |
Also seems to be that everything that I'm copying back off my USB HDD using Windows Buck-up is also ending up 'Write Protected' and
won't allow me to change or move it
