macnab
| posted on 5/1/07 at 06:29 AM |
caveman draws engine...
I may be wrong but isn't his one off the most technically inaccurate drawings of an engine ever??
ned
| posted on 5/1/07 at 11:49 AM |
is it a hybrid 2cv engine?
or is it some sort of 2 stroke arrangement sucking the gases through the crank case?
[Edited on 5/1/07 by ned]
beware, I've got yellow skin
macnab
| posted on 5/1/07 at 12:43 PM |
na it's more powerful than one off those...
Confused but excited.
| posted on 5/1/07 at 05:11 PM |
Why are the cylinder heads missing?
Why does it have unequal cylinders. is it steam powered?
Why is it cooled with urine?
What is the big nose for on the right of the picture?
Why am I asking these questions?
Where are my dried green frog pills?
iank
| posted on 5/1/07 at 05:19 PM |
Looks like a 2 stroke engine aeroplane engine without cylinder heads or an inlet.
The turbocharger (?) bevel gear driven to the crank seems interesting, maybe it actually pumps exhaust out quicker? Or it could just be wrong
carnut
| posted on 5/1/07 at 05:21 PM |
Looks to me like the yellow isnt the exhaust but part of a cooling system. The inlet and outlet may be in the heads which are missing.
IainB
| posted on 5/1/07 at 05:26 PM |
I thought 2 stroke inlet and exhaust had to be in the bore? surely it wouldnt work if they were in the head?
Please correct me if im wrong!
Iain
http://s43.photobucket.com/albums/e365/IainB1986/
iank
| posted on 5/1/07 at 07:20 PM |
Yeah, the yellow bit looks from the arrows like the exhaust, and if it went through the casting would be in the bore.
But agreed it might be the cooling system and the bevel thing driven thing would be a water pump, which would make more sense.
It gets worse the more you look at it.
| posted on 5/1/07 at 07:34 PM |
i bet some kid drew it knowing that a bunch of petrolheads would spend hours trying to work out what was wrong, what was what, and what needed
changing to make it work!
Looks closest to a 2 stroke with forced exduction, but as said, its ill in many ways
[Edited on 5/1/07 by JoelP]
carnut
| posted on 5/1/07 at 08:22 PM |
Just a thought, maybe its not an engine but is a pump.
| posted on 5/1/07 at 08:52 PM |
maybe a wind powered beer pump?
Tralfaz
| posted on 6/1/07 at 12:46 PM |
Wondering this, or if they are "trying" to recycle exhaust pressure "power" back into the driveline/prop.
Brian
macnab
| posted on 6/1/07 at 06:00 PM |
Ok, sorry guys but that's not the cooling pump
It's described in the book as the 'turbo charge system'
Oh dear...
Yip this is the most lame attempt at an engine ever, the jet engine diagrams aren’t much better either, book fit for the bin I think.
