posted on 28/2/08 at 01:09 PM |
Alternative Energy - a new solution!
People on this forum get all worked up about alternative energy - solar, windmills, etc.
Now there's a new answer... hamsters!
LINKY
Mr Whippy
| posted on 28/2/08 at 03:43 PM |
If I used them to power my Volvo, how much CO2 does several thousand hamsters produce?
The windmill info though looks pretty comprehensive
Confused but excited.
| posted on 28/2/08 at 04:04 PM |
Sod the CO2, what about the Methane?
Could you pipe their anal emmissions into the inlet manifold?
[Edited on 28/2/08 by Confused but excited.]
Mr Whippy
| posted on 28/2/08 at 04:11 PM |
| posted on 28/2/08 at 04:34 PM |
You could burn dried hamster poo...
Guinness
| posted on 28/2/08 at 06:58 PM |
I like the principle, but what if you fed the hamsters to something larger, like a cat. Replace dozens of small wheels with a single bigger wheel.
If that doesn't work, feed loads of hamsters to several cats and feed the cats to a tiger in a massive wheel?
Mike
| posted on 28/2/08 at 10:00 PM |
If public transport was powered like this, it would solve the overcrowded prison situation at a stroke.
Edit: The prisoners build up massive stamina and leg power, thus preventing the plod from catching them next time. So, no re-offenders.
DarrenW
| posted on 29/2/08 at 09:37 AM |
Would a single Cat to hamster ratio of 1:100 be like having a supercharger at 1 bar boost?
| posted on 29/2/08 at 11:29 AM |
You should be looking at lizards or amphibians as surely they would have better efficiency since they do not consume energy to keep body temperature
constant?
Then a matter of selecting one with the best power to weight ratio.
Mr Whippy
| posted on 29/2/08 at 12:10 PM |
just burn the hamsters
they are a bio-fuel as they turn into CO2 which is inturn used by plants which is then eaten by more hamsters
DarrenW
| posted on 29/2/08 at 12:23 PM |
All of a sudden £5 a gallon looks so much more appealing and less hassle.
| posted on 29/2/08 at 04:38 PM |
constant?
They depend on sunlight for heat/energy to raise their body temperature, so you wouldn't be able to drive at night.
