this might sound silly, but i remember reading something like this before somewhere...
i'm going to want to paint my prop shaft. the paint finish isn't great from the factory, and some has scraped off already. its not been run
on the car yet, so don't really want to get into taking it all apart and risk breaking it, so...
... can i just hang it from my garage roof and spray it? or should i mask up all the bearings and greasing points? i obviously don't want to ruin
it lol
Mask bearings. They should be sealed but, paint solvents can be quite thin.. Used a paint brush on mine, problem solved..
[Edited on 25/1/10 by Bluemoon]
I'd masking tape the any nipples before spraying.
This might sound dafter, but make sure you get an even coat all over, more paint on one side can throw them out of balance!!!!!.
Originally posted by iank
I'd masking tape the any nipples before spraying.![]()
^ if there is, i'll stick one to the other side too
ladybird i like it
I suggest you get it to lay on a sofa with one of it's UJs bent in a suggestive manner. You put on a smock and a big floppy beret, come in, set up your easel and say 'ze light iz perfect', paint away.
Surprised you hadn't thought of this yourself.![]()
awesome
so, if i make sure the nipples (he he) are taped up, i guess i can spray the rest, any paint on joints will just break up i suppose but obviously try
and avoid it as much as possible, and i can then re grease them just in case anything got in?
Originally posted by blakep82
awesome![]()
so, if i make sure the nipples (he he) are taped up, i guess i can spray the rest, any paint on joints will just break up i suppose but obviously try and avoid it as much as possible, and i can then re grease them just in case anything got in?
I used to build props for a living ........
The only parts we used to mask were the gearbox slip yokes (the part that slides into the gearbox). We didnt get paint on the flange surface becasue
we sprayed away from it.
I would not worry about the Uj`s, seals etc. Just wipe the paint off the nipple before greasing.
If you wanted to be absolutly correct you should mask the flange where the bolt heads sit. It is bad practice to have paint between clamped surfaces
and that includes under washers or bolt heads.
The only parts we used to mask were the gearbox slip yokes (the part that slides into the gearbox). We didnt get paint on the flange surface becasue we sprayed away from it.
If you wanted to be absolutly correct you should mask the flange where the bolt heads sit. It is bad practice to have paint between clamped surfaces and that includes under washers or bolt heads.
top man!
hopefully get a go at it later this week or next week
