I need to cut my ally floor pan into a curved shape, whats the best tool to use?
James
nibbler or jigsaw
Jigsaw with plenty of lube on the blade.
Or nibbler.
I have a nibbler but it takes a bite of about 2mm each time, it'll take years!!! I think a jigsaw will just rip and distort the panel - it's
only 1mm
James
Plasma cutter!
Nibbler but will leave evil bits.
Jig saw and spray the blade and alloy with WD40 or light oil
One of these ?
Well..........it's what I use at work
Hand nibbler - slow, but accurate and clean cutting.
Remember to oil the nibbler too.
1mm is easy to cut shears or snips --- tinsmiths snips, aviaton shears, air shear or bench shear or a bench wheel cutter.
BUT 1mm aluminium alloy sheet is way too thin for a floor --- without doing the maths a 2 mm floor would be about 6 times stiffer in
bending a still only half the weight of 1.5mm steel.
Its got to be a band saw, clean cut and ali is supported so no distortion.
Ive got the plasma, air niblers and jigsaw ect but by far the best tool for the job was a good set of tin snips
did you gat it pained in epoxy ? I am interested in your results.
for 1mm ally tin snips has to be the best easiest and quickest of all!! Make sure its a decent set.
If you have a compressor then one of these air shears will do the job lovely.
Rich
Cut all my ali with a stanley knife.... easy just score 2/3 times then wiggle it and snap. Nice clean cuts. You need a new blade as well.
Aviation snips, its what they are designed for, just regularly dip in parafin to give a really sharp cut.
I agree about the 1mm ally - only suitable for wrapping up a turkey
