hi guys,
im thinking about painting my ali side panels black, they are riveted and glued to the car so if i have a go it will have to be done with the panels
still attached, how do i go about it, what primer and paint do i meed, i want a shiney black finish (is this black gloss?)
help please
Had a chat with my mate who works at a bodyshop the other night about this.
I think this is what he suggested:
1. Rub down and clean up, remove all grease and dirt
2. Key up with wet and dry
3. Etching primer, a couple of coats
4. Rub down smooth with fine wet and dry
5. Normal primer, a couple of coats
6. (as 4)
7. Paint. Can be whatever you want but gloss will give shiny finish, a few coats
From there you can rub down again with rubbing compound and give another coat, then a coat of lacquer, rub down, and polish/wax for protected finish.
would i have to use spray, cuz i dont want brush marks, how fine a wet and dry will i need, i think the finest i have is p1000, i also have p800
600 from primer.
then go to 800, 1000 after doing each coats of gloss.
dilute the last coat with cellulose to go on top of flatted 1000; it shouldn't need cutting down.
To cut down on the amount of prepping onto ali. I'd be inclined to use Barcoat. My local paint supplier recommended it - as used by off-roaders
on their Landies.
A couple of top-coats - job done.
Cheers, Pewe
Originally posted by pewe
To cut down on the amount of prepping onto ali. I'd be inclined to use Barcoat. My local paint supplier recommended it - as used by off-roaders on their Landies.
Cheers, Pewe![]()
Oh yes! Def go for acid etch. Anything else will peel off pretty quickly and start looking horrible!!! Nasty stuff though so wear a mask!! I didn't and the wind changed and I almost choked to death!!!
1, Key up the ally with 240
2, Apply 1 light then 2 medium coats of high build etch, Glasurit do a nice one. Hand block with 400
3, Apply 2 coats of polyester black basecoat
4, Apply 1 light then 2 medium 1k clearcoat
Don't use any wet and dry, water is the last thing you want anywhere near the car paintwork. The primer is designed to chemically combine with
with the next liquid that it comes into contact with - that is better to be your colour coat and not the contents of a rubby bucket
