Glassfibre Repair Kit
Michael - 8/11/09 at 10:47 PM
I have seen a Glassfibre repair kit in my local motorfactors and wondered if i could use this to make my own Glassfibre bulge?
I can not tell if there is gelcoat in the kit.
The one i saw is same packaging but larger box.
http://www.screwfix.com/prods/86655/Van-Car-Accessories/Body-Repair/Glass-Fibre-Kit
austin man - 8/11/09 at 10:55 PM
standard kit no gelcoad so will need to use filler and smooth
BenB - 8/11/09 at 11:02 PM
That's basically just some chopped strand matt and some polyester resin and catalyst. As said you'ld really want some gelcoat (+ pigment unless you're going to spray it) for the outer layer and that's about it!
coozer - 8/11/09 at 11:05 PM
http://www.ecfibreglasssupplies.co.uk/store/-c-316.html?osCsid=41a3e5e1276a6a59d49a5df757727d2e
mad-butcher - 9/11/09 at 09:52 AM
expensive way of doing it using kits
Glasplies
tony
Michael - 9/11/09 at 09:09 PM
Thanks.
Did not think it had Gelcoat, but was told by someone at work i could use repair kit to make the bulge.
Will keep searching the net for one, and sounding like goldilocks will need to be just right.
Its going on a Ali Bonnet, so will be painted with the bonnet once done.
