Recomendation For Bodyshop In Scotland To Spray My Fury
JekRankin - 15/4/11 at 11:38 AM
Hi,
I’m looking for a recommendation for a body shop in Scotland to prep and spray my Fury bodywork for me.
The bodywork is currently in black gel coat and I think there will be a fair amount of prep work needed. Most surfaces are covered in ripples, there are some star cracks visible where the original mould has been damaged, and a couple of areas require a fair bit of attention - especially along the rear edge of the bonnet where the mould has poorly extended. The rear light recesses which I will be blending into the bodywork will probably need a bit of work too!
I’m looking to get the work done towards the end of summer. It’s a fair while away, but I’ll need to start saving now, and would like to get in touch with the shop well in advance with a few photos get an idea of the cost and timescale for the work!
Can anyone recommend a body shop for a good finish at a decent price?
Many thanks,
Jek
[Edited on 15/4/11 by JekRankin]
sdh2903 - 15/4/11 at 12:01 PM
I can recommend ian at probodyshop in Cambuslang. I had some work done on my tintop and I couldnt fault it, he was very reasonable with the cost too. It's only a small place and you may have a wait to get it done (usually a good sign) but if your not in a rush then it wont bother you anyway.
probodyshop
Humbug - 15/4/11 at 12:54 PM
Originally posted by sdh2903
I can recommend ian at probodyshop in Cambuslang. I had some work done on my tintop and I couldnt fault it, he was very reasonable with the cost too. It's only a small place and you may have a wait to get it done (usually a good sign) but if your not in a Rush then it wont bother you anyway.
probodyshop
No, he's in a Fury
sdh2903 - 15/4/11 at 02:29 PM
probodyshop
No, he's in a Fury
There's always one......
mangogrooveworkshop - 15/4/11 at 02:35 PM
probodyshop
No, he's in a Fury
Oh very good play on wordage
And back to the thread
It's fibreglass so tin places don'tlike scratching
Roddie Mathews up in Dundee does classic cars and boats for
a living. 01382 581752
His rates are very reasonable and he can do stage payments.
Rod painted the yellow mango car .I once owned.
TimC - 15/4/11 at 02:41 PM
As per Mango's advice, do not even entertain using a bodyshop that doesn't have extensive experience with GRP.
JekRankin - 16/4/11 at 07:04 AM
Thanks guys,
I'll give Roddie a ring and send him through some photos of the nasty bits to see what he thinks.
Jek
