Anyone tried to make a bespoke curved screen
Irony - 4/5/11 at 12:53 PM
Even though I am no way near my IVA I am thinking about post IVA projects for the car. I guess I wouldn't be building a car if I wasn't a dreamer.
I am going to put the Viento through the IVA windscreenless and then at some future date build a screen for it. I work quite closely with a plastics suppliers and the MD has been in the trade for years. He gave me the idea. I plan to create a curved bespoke wrap around windscreen to go on the Viento. I will do this by creating a wooden mould that is the shape of the windscreen, then lie a sheet of 10mm polycarbonate over the mould and heating the whole thing up in a large metal box so the plastic begins to droop around the shape of the mould. When gravity has done its work I should be left with a curve bit of polycarbonate which I can trim and shape to the desired measurements. I then plan to have two metal uprights laser cut for each side and a central support as well. The rest be supported by some sort of U-shape rubber trim, which is just really used to keep out wind and rain. I realise that the polycarbonate will probably need repolishing but I can do that no worries. I can also cover the poly in a clear vinyl to add damage and shattering protection.
I am imagining a screen at rakish angle and a cool shape. Anyone have any thoughts on this? Impossible? Not worth it or just plain naff?
russbost - 4/5/11 at 01:02 PM
Not done anything quite that ambitious but managed to make a curved screen for the Furore using 4mm polycarb, a bit of heat & free forming, worked a treat!
Bluemoon - 4/5/11 at 01:05 PM
Possible, but you can't use wipers on the screen as it will scratch, so fine if you don't use it in the rain.. As you can't have wipers you must remove for MOT.
As to the method it should work, it is one method used for forming polycarbonate, most polycarbonate suppliers datasheets will tell you how to do it. The trouble is the price of the ploycarb and how many times you need to try to perfect the method and get a good one!
Dan
[Edited on 4/5/11 by Bluemoon]
Irony - 4/5/11 at 01:08 PM
I bent some 4mm the other day using a mould and a blow torch for some curved panels in the greenhouse. Worked a treat until I got a bit carried away and set one on fire. hehe. Still worked though
Irony - 4/5/11 at 01:12 PM
Dan
Kinda hoping to avoid the whole wiper issue to be honest - I don't intend on driving in the rain hopefully but no doubt it will be impossible to avoid
contaminated - 4/5/11 at 01:15 PM
Dan
That's why you need to consider how high the screen is and whether you will be able to peer over it. If you can't and you have no wipers you are in for a dodgy drive home at some stage - like when I used to run a screen and the wipers packed up
Chippy - 4/5/11 at 01:25 PM
Guy I know built a curved screen or his Robin Hood from an MG one used the side suports, and then had the glass cut down to fit. Looks very smart. HTH Ray
RazMan - 4/5/11 at 03:48 PM
I got one made by Pilkington Glass along with some side windows too (all curved)
I made a buck by forming some 4mm Lexan over some 'ribs' and gluing the whole lot together with epoxy. It worked really well and the glass came back faithful to the buck's shape.
Be aware that it was not a Locost experience though
Johneturbo - 4/5/11 at 03:54 PM
Can you not use RainX or whatever it's called so the water beads off, if you got cought out in the rain
Mal - 4/5/11 at 04:45 PM
I got a curved screen for the car I built by having a production Escort laminated front screen cut down t othe size of a template I supplied.
Rod Ends - 4/5/11 at 07:23 PM
Very recently, in one of the Classic Car mags. there was an article about a company that made custom screens.
Unfortunately, the company went bust as the mag. went to press.
Not sure if they survived or have been resurrected.
