I received this contraption today. Dont really know how to put it together, Any pointer would be appreciated. Thanks alot.
[Edited on 16/5/11 by femster87]
Windscreen - I've got a pic like that!
GBS 'lightweight' windscreen
You get the flat piece of rubber, and fold it into the channel. Then you push the glass into it.
Like this....
Then you do the same with the bottom, and you will need to cut the ends to mitre the corners, finish by CAREFULLY drilling diagonally at the corners
so you can fit a screw at each side. I will say it is definitely not easy. Use 'Mr Muscle' cleaner to help ease the glass into the
rubber seating.
thank you very much, really appreciated would have a go tomorrow. thanks
Have a read at this linky
