Hi can anyone let me know if I fit an aeroscreen to my Mk Indy will it leave visible holes if I later want to fit a proper windscreen?
Cheers Chris
Depends on the type of aeroscreen.
I had a Mac1 polycarbonate aeroscreen on that bolted through the upright bit on the scuttle and now have a Caterham full screen. None of the holes
from the aeroscreen are visible.
Stu
Cheers Stu I think I will have to look at one or two other cars to see how to fix the aeroscreen but thanks for the advice.
All mine is held on by is the 2 bolts on either end for the mirrors. If i wanted a proper screen later i would still have the mirrors in the same
place and no extra holes.
Did the windscreen to aero conversion on a Westy and found there were visible holes (not helped by original poor fitting by original builder. I used a carbon mods aero, fitted well but wouldn't cover all the holes. Most guys in Westy club who run both make up a quick release alternative scuttle. Not sure of the fixing points for an MK aero and screen!
